tune causing wastegate not to open after 24PSI
Old 03-10-2014, 01:07 PM
hucks1987's Avatar
Hey guys,
Quick question, I have the Hahn 20G and was tuned for 24PSI using the stock boost controller, I have now added a ZZP manifold and Tial 38MM WG and a Hallman BC. But for whatever reason, If I turn the boost contoller to anything higher then 24, my wastegate wont open, I think i have a 20-22Lb spring in the WG itself.
So because i was tuned using the stock Boost controller, is there something in the tune that will cause it not to open? something that will limit it to only 24PSI?
Old 03-10-2014, 01:41 PM
LNFTX's Avatar
Originally Posted by hucks1987
Hey guys,
You might read thru dartsi bnr thread I think at one point he had nearly the same issue
https://www.cobaltss.net/forums/2-0l-lnf-performance-tech-153/bnr-losing-boost-top-end-274214/
Old 04-09-2014, 01:02 PM
hucks1987's Avatar
Yea, It was the tune, My setting with the stock boost controller was set at 24, so thats as far as it would go
05-28-2022 03:47 AM
Tupp
2.2L LAP Performance Tech
01-02-2016 12:04 PM
ineedacobaltss
11-07-2015 02:25 PM
soaxin
09-26-2015 08:41 PM
soaxin
09-26-2015 08:39 PM
Quick Reply: tune causing wastegate not to open after 24PSI
