Tuned by Terminator
I finally got tuned by Term and I could not be any happier seeing as I'm only on 91 octane
All were 3rd gear pulls
Max was 310fwhp and 380ft lbs @26 psi
I found out after the dyno 4th gear is optimal for checking the power...poops! I'll update once I re-dyno properly.
So far I'm loving the strong power band
3rd gear pulls compared to 4th gear pulls won't make much of a difference as far as power output on the stock turbo. There is no 1:1 ratio in the F35. 3rd is slightly underdriven and 4th is slightly overdriven. The only time 4th makes a bit more power is with larger turbos.
