Wideband Readings on LSJ Cobalt
Just installed my AEM wideband on my cobalt sc to see what afr's it was running, turns out its running really lean in boost. Mid 12's to mid 13's at full boost, anybody else had any weird readings like this?
Not sure. I'd assume they would. I don't have an AEM though....
My wideband self calibrates at startup, and I manually calibrate twice a year.
If they dont, and the OP's A/F ratio's are in fact mid 12's to 13's he will need that checked out asap.
Yeah the AEM's dont require calibration they just go bad over extended use.
OP what tune are you on? If you got tuned without the wideband i'm not surprised you're running lean, you need really good injector tables to be spot on (some tuners do have access to this information)
Josh@ottp
09-08-2015 10:18 AM
XStylus
Redline Goods
17
09-03-2015 10:30 AM
