17 x 9 with 275/40's are on!
Haz l33t wheelz.
My original wheel bearings are shot after 15 000km's... wonder why
The backspacing is the same as stock so I have enough clearance on the inside and they clear the Brembo's. The 275 will be too wide, but according to my calculations a 245 will be fine in the rear and I could probably go to a 255 on the front if I want.
I will keep a close eye on the new wheel bearings/hubs at the track and will let you guys know how they hold up. You do not want to do this mod yourself though, the drilling/backfacing needs to be done by professionals in a machineshop.
thanks for the compliments guys
Will keep you posted buddy!
I was running 245's on a 7.5 rim with a +38 offset all the way around for 2 years, all you have to do is roll your fenders slightly(literally, just the lip on the inside) in the back if you decide to get low. About 6 months after I put them on I dropped 2F/2.5R with no other serious issues. I am running 225's in the front now because I am also going for a nice stance.
