How easy/ hard to make these work?
So, stumbled across these as a possible new set of wheels for the time attack car:
http://www.ebay.com/itm/17X9-STR-517-4X114-3-20-ORANGE-BLACK-FACE-WHEEL-FIT-HONDA-ACCORD-PRELUDE-240SX-/400676374810?hash=item5d4a2c491a&vxp=mtr
STR 517's. Only thing is offset is only a +20 not the 35/45 like the balt wants.
Is there any way to space these out that it wouldnt either 1) look weird or 2) have terrable fitment / be a safety issue?
You need a hub swap. Minimum width of adapters is either 20MM with extended studs or most are 25-28mm. You subtract that from the offset. So with a 25mm adapter youd have a -5 offset. FAAAAHHHGETABOUT
Hubswap to 4x114 and they will fit nicely. Should be around $450 to do so.
Slobodan Miloević
+20 is going to be mega hellaflush status, I have 245/40's on a +40 17x9 wheel and it fills out the fender in a normal way. +20 is going to require a fender roll, and some seriously stretched tires on a 9"wheel. definitely not going to be race car fitment
*waits for stanceboys to chime in with "its not that bad"* lol
