Just an FYI on new 17x8 Wheels...
Thought some of you might want to know. I found these on Discount Tire Direct. Good price too! The only question is will they clear Brembos?
RAGE R10 17x8 in 5x110
Wheel Details - Discount Tire Direct
RAGE R20 17x8 in 5x110
I lik the look, knock off wheels cheep that dont look too bad.
I was thinking about getting some for summer wheels and wider summer tires and turning my stock wheels into winter wheels/tire setup. but I dont want to spend 700+ on summer wheels.
And I thought the same thing wert842 They should fit but i wanted to see if anyone had done it and could verify.
Discount tire is running a $50 saving on the R20s right now. I damaged the hell out of my winter rims last year (bent 3 of them) which will cost me at least $300 to have repaired. I can get 4 of these for a tick more. I am really debating picking up a set in 17" for this coming winter.
I ordered them about 2 hours ago actually. The tires I want on them are on backorder so I should have them in 2 weeks. I'll test fit them when I get them and take some pictures.
So these came in today while I was at work:
I have two of these mounted with tires as well. I didn't open them up yet. Tomorrow I will jack the car up and test fit these to make sure everything clears. I'll post more pictures once I do that.
Thats a good deal only thing that drive me nuts is the multiple bolt pattern alot of those cheaper wheels have. Id take a set of those for some slicks if they clear the calipers.
I test fitted one rim. It fit fine and clears the brembos by a good 1/3" if not more:
I did notice they are not hubcentric, so I will need to order rims. Also, the lugs don't fit. The lug is the exact size of the hole, meaning I can't get a socket on it. So I will need to order a set of lugs.
Here's a few more pictures:
And the packaging from Discount Tire with a tire mounted on the rim:
Wow for the money those look pretty good! Majority of the time when you go with an aftermarket wheel you have to use tuner lug nuts...you can get a decent set for about $20 on eBay.
I had a set of Borbets before this and they accepted the factory lugs just fine. Not a big deal to pick up a set of lugs and hubcentric rings. I'm not in a rush to get these on the car. I generally put them on in mid December.
Something like this for lugs?
http://www.ebay.com/itm/20-SPLINE-TUNER-RACING-LUG-NUTS-12X1-5-FITS-CHEVY-CAMARO-CORVETTE-COBALT-S-10-/331085776821?pt=Motors_Car_Truck_Parts_Accessories&hash=item4d164007b5&vxp=mtr
Sure, I just got plastic hubcentric rings off ebay:
http://www.ebay.com/itm/331286904188?_trksid=p2060778.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
The R20s hub is 73.1mm and the Cobalt is 65.1mm. They also sell aluminum ones for double the price. I had plastic on my other set of winter rims and they worked just fine. I had aluminum ones on rims I had for another car and all they ended up doing was slicing my fingers whenever they got stuck to the hub and I tried taking them off to replace the rotors.
