Just an FYI on new 17x8 Wheels...
Old 07-05-2014, 09:53 PM
baltman51's Avatar
Thought some of you might want to know. I found these on Discount Tire Direct. Good price too! The only question is will they clear Brembos?
RAGE R10 17x8 in 5x110
Wheel Details - Discount Tire Direct
RAGE R20 17x8 in 5x110
Old 08-31-2014, 10:40 AM
crashher0's Avatar
Anyone know if the 18x8 clear brembos of the lnf?
Old 08-31-2014, 10:53 AM
chevygirl2006's Avatar
Those wheels are like $450 shipped on eBay. I might get them. Been looking at them for a while.
Old 08-31-2014, 10:55 AM
Wert842's Avatar
They should fit over brembos seeing as they are a +40 or +42 offset.
Old 08-31-2014, 12:01 PM
crashher0's Avatar
This
I lik the look, knock off wheels cheep that dont look too bad.
I was thinking about getting some for summer wheels and wider summer tires and turning my stock wheels into winter wheels/tire setup. but I dont want to spend 700+ on summer wheels.
And I thought the same thing wert842 They should fit but i wanted to see if anyone had done it and could verify.
Old 09-09-2014, 09:12 AM
NickD's Avatar
Discount tire is running a $50 saving on the R20s right now. I damaged the hell out of my winter rims last year (bent 3 of them) which will cost me at least $300 to have repaired. I can get 4 of these for a tick more. I am really debating picking up a set in 17" for this coming winter.
Old 09-09-2014, 09:27 AM
heeter_33's Avatar
The links don't work for me for some reason.
Old 09-09-2014, 09:29 AM
NickD's Avatar
You might need to visit discounttire.com first and punch in your zipcode. They work fine for me.
Old 09-12-2014, 01:40 PM
crashher0's Avatar
If you pull the trigger on these NickD let me know how they wrap around the brembos. I may be getting a set next spring or over the winter as a cheap summer wheel to wrap summer tires on so my winter tires can finally take a break.
Old 09-12-2014, 01:52 PM
NickD's Avatar
I ordered them about 2 hours ago actually. The tires I want on them are on backorder so I should have them in 2 weeks. I'll test fit them when I get them and take some pictures.
Old 09-12-2014, 01:54 PM
crashher0's Avatar
did you end up going with 17s then?
Old 09-12-2014, 02:00 PM
NickD's Avatar
Yeah, I definitely want the 17"s for my winter rims. I got them from discount tire. Wasn't too bad, pretty cheap. They are also running a $50 rebate on them. So they're $346 shipped. I had tires and valve stems tacked on.
Old 09-17-2014, 09:30 PM
NickD's Avatar
So these came in today while I was at work:
I have two of these mounted with tires as well. I didn't open them up yet. Tomorrow I will jack the car up and test fit these to make sure everything clears. I'll post more pictures once I do that.
Old 09-17-2014, 09:38 PM
LNFTX's Avatar
Thats a good deal only thing that drive me nuts is the multiple bolt pattern alot of those cheaper wheels have. Id take a set of those for some slicks if they clear the calipers.
Old 09-18-2014, 04:13 PM
NickD's Avatar
I test fitted one rim. It fit fine and clears the brembos by a good 1/3" if not more:
I did notice they are not hubcentric, so I will need to order rims. Also, the lugs don't fit. The lug is the exact size of the hole, meaning I can't get a socket on it. So I will need to order a set of lugs.
Here's a few more pictures:
And the packaging from Discount Tire with a tire mounted on the rim:
Old 09-19-2014, 09:54 AM
chefhhr's Avatar
Wow for the money those look pretty good! Majority of the time when you go with an aftermarket wheel you have to use tuner lug nuts...you can get a decent set for about $20 on eBay.
Old 09-19-2014, 10:18 AM
NickD's Avatar
I had a set of Borbets before this and they accepted the factory lugs just fine. Not a big deal to pick up a set of lugs and hubcentric rings. I'm not in a rush to get these on the car. I generally put them on in mid December.
Old 09-19-2014, 10:25 AM
NickD's Avatar
Something like this for lugs?
http://www.ebay.com/itm/20-SPLINE-TUNER-RACING-LUG-NUTS-12X1-5-FITS-CHEVY-CAMARO-CORVETTE-COBALT-S-10-/331085776821?pt=Motors_Car_Truck_Parts_Accessories&hash=item4d164007b5&vxp=mtr
Old 09-19-2014, 10:42 AM
Administrator
Administrator
Staged07SS's Avatar
^yes.
Old 09-23-2014, 09:23 AM
NickD's Avatar
^yes.
Thanks, I ordered those, they came yesterday and they fit right in there no problem. I payed all of $22 for lugs and hucentric rings.
Administrator
Administrator
Staged07SS's Avatar
Great!! Glad they worked out.
Old 09-23-2014, 02:47 PM
8urv8's Avatar
Any pics of the r20s on the car, tires and all?
Old 09-23-2014, 02:51 PM
NickD's Avatar
I won't be putting them on until winter nears. Hopefully not until mid-December.
Old 09-24-2014, 10:50 AM
8urv8's Avatar
Will you put a link up with the hubcentric rings you got?
Old 09-24-2014, 10:59 AM
NickD's Avatar
Sure, I just got plastic hubcentric rings off ebay:
http://www.ebay.com/itm/331286904188?_trksid=p2060778.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
The R20s hub is 73.1mm and the Cobalt is 65.1mm. They also sell aluminum ones for double the price. I had plastic on my other set of winter rims and they worked just fine. I had aluminum ones on rims I had for another car and all they ended up doing was slicing my fingers whenever they got stuck to the hub and I tried taking them off to replace the rotors.
Quick Reply: Just an FYI on new 17x8 Wheels...
