will they fit?
will they fit?
I found some bronze str 526 rims on ebay I like but they are 17x9 front and 17x10 rear this is going on a 08 Cobalt ls 2.2l, it is lowered but I have no idea what manufacturer the lowering kit is on and if it's just springs or full coilovers I will have to check with this being said I would plan to get a coilovers kit if needed
So the big question, will it fit without rubbing or should I get somthing alittle less wide
Supporting Vendor
Assuming the offset is low enough to not hit the calipers (maybe 40 or less), it will be extremely difficult to find tires that will be wide enough to fit the wheels safely and still be small enough in diameter to work without rubbing.
I'd take a pass for sure
Delta coupe
09-30-2015 08:11 AM
