ZZ Performance ZZ Performance is a proud Supporting Vendor
7163 zfr
Old 07-01-2015, 10:40 AM
  #276
This, i wanna know how it is with no ramp because id like one for my car.
I'm thinking about it also, since I could have it hold 22-23psi on e47 and I'd be happy due to the top end pull of the EFRs
Old 07-01-2015, 12:10 PM
  #277
nathan112i's Avatar
the top end of this turbo is unreal compared to a k04/k04r. you never want to shift because it keeps making more power the higher you rev. the initial price of this turbo holds people back from buying it but the simplicity of a bolt on turbo that makes this much power is a no brainier
Old 07-01-2015, 01:08 PM
  #278
KMO43's Avatar
So hows the boost come in on the 7163?
I'm at 23psi at 3500 i was getting surge so I had to bring the boost in smoother
My car at 23psi on very low timing was as fast as my K04r on 28psi at 20*
Old 07-01-2015, 01:14 PM
  #279
Any chance you'll log the dyno pull? boost, maf lbs/min, STFT?
Old 07-01-2015, 01:19 PM
  #280
KMO43's Avatar
I prob will be. I believe I have a boost leak that I'm gonna go look for right meow
Old 07-01-2015, 02:12 PM
  #281
LNFwagonSS's Avatar
Sorry if this has been asked....I seem to remember this turbo having wastegate canister options? If so, what are you guys running and why.
Old 07-01-2015, 02:33 PM
  #282
I'm gonna guess they're running the hi-boost canister. Since the EFR data recommends the high boost so you don't have to pre-load the **** out of it
Old 07-01-2015, 03:23 PM
  #283
nathan112i's Avatar
well kmo43 started out with high boost canister and is now running a medium, when i ordered mine i asked them to put a medium canister on
Old 07-01-2015, 04:17 PM
  #284
KMO43's Avatar
I'm running a medium it was surging really bad with the high boost and I wanted better control of the wastegate on spool so I changed it. I have the high boost so I may switch but I think that an actuator right between the 2 would be perfect
Old 07-01-2015, 05:47 PM
  #285
LNFwagonSS's Avatar
Any idea what psi each canister/actuator is rated to?
Old 07-01-2015, 06:13 PM
  #286
Get you a clutch son
Old 07-01-2015, 06:21 PM
  #287
KMO43's Avatar
http://www.full-race.com/store/image...-content-3.jpg
Old 07-01-2015, 06:56 PM
  #288
LNFwagonSS's Avatar
Sheesh, I see what you mean about wishing there was a canister between med and hi....kind of a large gap between the two
Old 07-01-2015, 07:23 PM
  #289
Damn im gonna need one hell of a boost controller if i get this
Old 07-01-2015, 09:45 PM
  #290
Sharkey's Avatar
turbosmart does make a wastegate actuator that you can change the springs in, give a lot more control.
  #291
Terminator2's Avatar
At your altitude 26psi would be fine I think on E-47 it should have enough fuel. Heck even E-30 you could get close to 20* timing and 27psi most likely and still have fuel. You would want the high boost canister though at your altitude as the medium will likely struggle to go above 24-25psi even at 100% wg dc.
Old 07-01-2015, 10:21 PM
  #292
Hence why stopping 22-24ish for fueling reasons and thats more than enough power for me, Adrian's car is stupid fast and I don't need that
Old 07-02-2015, 09:27 AM
  #293
Yeah 24psi on E-47 would be pretty damn quick. Close to Adrian's car most likely. Medium boost canister at 95-100% wg dc will normally hit around 24psi at your altitude most (set boost limit to 255kpa) and pressure vs rpm factor to 2.9-3.0. Unless you want me to tune it lol.
Old 07-02-2015, 09:51 AM
  #294
KMO43's Avatar
What's ur altitude?
Old 07-02-2015, 02:04 PM
  #295
If I get a zfr we'll be in contact
What's ur altitude?
from 5300' to 6300' drag strip is at 5800'
Old 07-02-2015, 02:19 PM
  #296
KMO43's Avatar
I'm at 3200 and I'm thinking about swapping to the high boost but I wish it was fully open at 26psi not 32
Old 07-02-2015, 02:43 PM
  #297
What's ur altitude?
High as hell close to 6000ft. Barometric pressure is around 82kpa not 101kpa like at sea-level
Old 07-02-2015, 02:53 PM
  #298
On the 6758 0% wg duty cycle with the high boost canister results in around 20-21psi at sea level.
Old 07-02-2015, 03:15 PM
  #299
The air density is normally above 6000'
not to mention all that legal weed making things high as hell (couldn't resist it)
Old 07-02-2015, 03:40 PM
  #300
KMO43's Avatar
At around 1500ft at 0% wgdc I would hit 32psi on the high boost
Quick Reply: 7163 zfr
