09 BPV solenoid removal.
I can run the stock BPV directly from the IM and cap the charge pipe vacuum line; correct?
No need for the electric solenoid? |
No one?
Or do I have to ask about painting my brakes or what color plastidip to get views? |
Wouldnt you get a code if you dont have the electric solenoid? I wish i could help but i dont know the answer lol
Ya you can run it right off the manifold no problem. You'll either have to leave the solinoid itself electrically plugged in or have the code removed through the tune or it will throw a light. Won't effect anything tho.
yeah I don't think it does once I disconnected the solenoid and forgot to reconnect it, I got the code but I never really noticed a difference in performance. but I didn't really know it will affect anything in the long run
I understand what is being done, But I don't know the purpose of it.
If someone doesn't mind explaining I would like to know why someone would do this? What is the benefit of doing this? |
Originally Posted by T-fog
(Post 7514756)
u can run it from the intake manifold port, but not from the lower charge pipe port, that one only sees boost not vacuum, which u need to open the bpv. if u do go straight from the intake manifold, u will have to put a hose on the solenoid from the bpv port to the bottom port on the solenoid, if u just leave the bpv port open when u switch gears or whatever, ull have a vacuum leak at that port, and while in boost, u will have a boost leak at that port, the way the solenoid works is when ur in boost, the top port on the solenoid that is connected to lower cp is open pushing boost on the bpv holding it closed, when u shift or whatever, that port closes and the bottom one opens providing vacuum to the bpv, opening it. that should help you. if u have a zzp lower pipe u can just remove the vacuum nipple and put a plug in, then u can just completely remove all vac lines from solenoid and just plug the bpv straight into intake manifold and nothing else.
Originally Posted by kzak104
(Post 7514763)
I only didnt it to run a bov my my turbo kit. Solinoid didnt open fast enough. Other than that I dunno why someone would remove it.
and regardless what u do, leave the electrical connection on the solenoid plugged in
Originally Posted by tomj77
(Post 7514776)
Or that. I don't like deleting codes, wish u could just turn things off. Like rear O2 , I can delete the code cause when it gets full of moisture it pops, but even so car will still start funny. So I just leave em. Not that it would happen with that.
(Post 7514794)
You could scan it every other day
(Post 7514812)
Lol annoying but you could
to much work for me :P ill delete the codes, haha
:lol: i would too
(Post 7514809)
You just drive with a check engine light? How do you know when something is actually wrong?
(Post 7514836)
I don't delete the codes, when it pops, I fix it. |
(Post 7514841)
When what pops. The cat? The solinoid? I'm confused
oooh, i see, i dont delete the o2 sensor codes, just the cat efficiency code
Thanks guys.
I'll delete the code. I just wanted to make sure the BPV could do it. |
