400+ whp
Old Jan 11, 2014 | 04:01 PM
MarkJr's Avatar
400+ whp
What's the best way to make over 400whp without doing the motor or turbo as far as I know the car has the gms1 turbo but not sure how to find out besides it make like 25lbs of boost any input is appreciated
Old Jan 11, 2014 | 04:05 PM
kzak104's Avatar
wont get there on stock turbo. buy zfr
Old Jan 11, 2014 | 04:27 PM
MarkJr's Avatar
I'm pretty sure its not a stock one it will make 25 lbs of boost seen higher but that's where it levels off guessing its the gms1any other ways I can check it and tell?
Old Jan 11, 2014 | 04:42 PM
2K10SS's Avatar
The stock turbo can run 30psi but it doesn't mean its efficient.alot of cars run 24psi on stock turbos.i run a 24 psi tune and half full bolt ons and make 318hp 406tq.
Old Jan 11, 2014 | 04:47 PM
MarkJr's Avatar
There anyway to look and see which turbo it is guy bought it from gave me some numbers and I looked it up showed like a 56mm
Old Jan 11, 2014 | 04:58 PM
Wert842's Avatar
Look at the serial numbers, make, and any idicators on the turbo. Stock turbo tuned can make 25lbs but no where near 400.
Old Jan 11, 2014 | 05:08 PM
SLRdohc's Avatar
If you saw what it is, then you should know what turbo it is. P.S. psi means absolutely nothing.
Old Jan 11, 2014 | 05:17 PM
MarkJr's Avatar
Thanks guys I'm new to this kind of stuff I'm use to our race cars we have two camaros with 540ci and twin precision turbo 94s
Old Jan 11, 2014 | 05:40 PM
You won't have to build the motor, but you will need a bigger turbo if you want 400.
Old Jan 11, 2014 | 06:19 PM
MarkJr's Avatar
How much will the zfr add just swapping the turbo nothing else?
Old Jan 11, 2014 | 06:33 PM
Wert842's Avatar
zfr on pump gas is roughly 370-380 on a decent good tune. zfr has a huge powerband though.
Old Jan 11, 2014 | 06:34 PM
574's Avatar
574
Depends on if you use regular or e85 and how much psi you have it tuned to. I wouldn't vote for the zfr, spools too quick and wrecks transmissions. You don't sound like the type that wants to deal with upgrading the trans
Old Jan 11, 2014 | 06:40 PM
Wert842's Avatar
Lol on your last sentence, so spot on... ZFR is the best bang for your buck up front and has an immense powerband over most others. For every need under the sun though, it is a top knotch part and gets the job done. Not everyone is shooting for 600.
Old Jan 11, 2014 | 06:43 PM
574's Avatar
574
Haha well at first he said he didn't wanna build the engine or upgrade the turbo, so I would say it's safe to assume he doesn't wanna replace the trans. Get 4.45 trans and zfr and it is a pretty good bang for buck
Old Jan 11, 2014 | 06:47 PM
Wert842's Avatar
Spot on there. 4.45 mated with the zfr is nucking futs. Completely underestimated. Take it from me
Old Jan 11, 2014 | 06:48 PM
574's Avatar
574
I need to pull the trigger and get 4.45's put in mine
Old Jan 11, 2014 | 06:51 PM
You're going to want an intake, downpipe, charge piping, and intercooler as well and obviously a tune.
Old Jan 11, 2014 | 06:54 PM
Wert842's Avatar
What he said.
Better find a set while you can!
I miss my old girl...
Old Jan 11, 2014 | 08:05 PM
MarkJr's Avatar
Thanks guys I appreciate all the help I don't mind working on anything that's what I do for a living is build racing engines I just was curious if it was possible to make 400whp without changing the turbo or messing with the motor I just having been able to find out the specs on the gms1 turbo that supposively on the car but sounds like I'm going to save some money and do the zfr sounds bad ass.
Old Jan 11, 2014 | 08:06 PM
MarkJr's Avatar
Now I need to put a clutch in it first before do all of this the one that's in it is in now is slipping
Old Jan 11, 2014 | 08:08 PM
No such a thing as a GMS1 turbo. All GMS1 consists of is sensors and a tune.
Old Jan 11, 2014 | 09:03 PM
MarkJr's Avatar
That's where I'm confused told something was upgraded by factory to keep the warranty and has a upgraded turbo of some sort need try find some numbers on the turbo on the car see what I have thanks for the input
Old Jan 11, 2014 | 09:12 PM
09CobaltSS1's Avatar
Like bmartz1991 said, the gms1 is nothing more than 3bar map sensors and a reflashed ecm through GM. The turbo remains the same as stock though. The stock turbo is only good for roughly 35lbs/min of max flow so there's no way you'll hit 400whp with the stocker.
Old Jan 11, 2014 | 09:38 PM
footballplaya3k's Avatar
GMS1 is the sensors and tune like people have been saying, that's it. GM has no other turbo for our car.
Old Jan 12, 2014 | 01:35 AM
GTOworshiper9's Avatar
It's a good thing you made this thread because your questions have never been asked or answered. Ever.
