AFR Gauge
AFR Gauge
Ok im thinken of getten a guage to monitor my AFR...Do i need a wideband O2 sensor or can i tap off somewhere else..sorry kinda new to AFR...Reason i ask is im thinken of getten a DP and would be easier to have then add a bunge then take it somewere afterwards to get one added...Thanks Guys
your car has wideband sensors stock. you just need to get a gauge to display it. look at this thread: https://www.cobaltss.net/forums/show...15&postcount=9
ok so im kinda new to the interceptor. The point of running two is so you can see 4 parameters at once right??? and orbalt08 you wouldnt happen to be able to tell me which is the correct series would you?
I guess you could use it to see 4 parameters at a time. You could also set it up to cycle through and you can see all the parameters. For the LNF i believe it was the CN series. I know that the one for SC's will not work on our cars. I'm pretty sure it would be the same for the hhr as well. I did a how-to, let me see if I can post a link for you. Install was a piece of cake!
Dual Interceptor Install
Why limit your self to only 4 parameters when you can have upto 26 on one screen with the dashdaq? The dashdaq is so much more flexible than the interceptor gauges. http://www.youtube.com/watch?v=jyHS4s1MZxs
Install is as easy as plugging it into the obd2 port.
Same place you would mount a gps, either at the lower left part of the windshield or anywhere else. Oh an you can also get a gps kit for the dashdaq.
Your other option would be to get a wideband kit that includes the guage/controller and wideband sensor, these normally cost around $300 or so.
so has anyone for sure had the dashdaq, or dashhawk installed in a cobalt and know what it will and wont display for sure. i called msd and they said they weren't for sure if it would work or not wtf???
What do you want it to read? The dashdaq read's everything from my lnf ecm.
