anyone ever had this problem..
Old Jan 1, 2010 | 01:57 PM
sswitnutz's Avatar
i went to turn my key off and it wouldnt turn back...basically it was stuck on..
Old Jan 1, 2010 | 02:21 PM
northvibe's Avatar
if its new the key is pretty rough and not warn in...but you got it off right? could be a bad cut key or the lock mechanism. did you try your spare key?
Old Jan 1, 2010 | 02:28 PM
fakameanrepresent's Avatar
happy new year and good luck on the problem.
Old Jan 1, 2010 | 02:33 PM
jefferyss's Avatar
i had this problem when i had my ss 2.4....it turned out it was the neutral saftey switch had fried and teh dealership had to warranty it
Old Jan 1, 2010 | 09:36 PM
sswitnutz's Avatar
well the worst damn thing happedned..the key snapped off in the ignition..i talked to a dude that works at the dealership since they were closed 2day..and he said it happens every once in a while that sumthin gets stuck..my car was runing for a while...couldnt turn it off...i had to pull my fuel pump fuse and dissconnect the battery..and i left it at the dealership...man i tell you ive had a decent amount of problems with this car..e-brake dont work ..broken shifter cables..now this...wtffff
Old Jan 1, 2010 | 09:43 PM
outtamymind's Avatar
for future reference don't try cranking the key that hard, it should be a fluid motion. and also for future reference under the steering column is a lil tab that can be opened up, revealing a manual key lock override. you press that in and you can turn your key.
Old Jan 1, 2010 | 09:50 PM
Maupin SS/SC's Avatar
hold down the spring under the wheel. be more patient
Old Jan 1, 2010 | 10:42 PM
jefferyss's Avatar
show me ...
whaaaa ? how about you show me too ?
Old Jan 1, 2010 | 11:05 PM
rukkee's Avatar
You couldn't stall the car with the clutch?
Old Jan 1, 2010 | 11:09 PM
sport08's Avatar
haha i thought the same thing.....unless he's got a auto 2.4 ss....
kenny5969
Apr 30, 2015 02:44 AM
dragon_slayer
Apr 12, 2014 03:02 AM
MasonSS
Mar 16, 2014 10:07 PM
Stick
Mar 13, 2011 09:28 PM
strykr
Jun 15, 2010 11:37 PM
