Brembo caliper replacement??
Hey guys was just looking for a "How to" to changing out brembo calipers......i had to make cuts in mine in order to get seized pins out.....sucks but i tried everything from cutting the pins to drilling and torching
Thanks!! I guess a better question would have been is there anyway to replace the caliper without bleeding the system......i remember reading somewhere that if you clamp the brake line with a pliers/vice grip with some rubber tubing so you dont damage the line you wouldn't have to bleed the system but i was a bit skeptical.
Next question would be do I only have to bleed that one wheel where I am replacing the caliper or all 4??
Def have to bleed it, even clamping the line there is an air pocket where the line meets the caliper. Its no big deal really, you can get a vacuum bleeder at harbor freight that works great for less the $30 that makes doing it yourself a snap, or a helper and $3 worth of vacuum hose. You should be ok with bleeding just that side. Just keep an eye that the master cyl stays full.
