Check Engine Light
Check Engine Light
so i was driving tonight and i got on it from first to third. as soon as i hit second gear my CEL went on. so i started to freak out, then i drove normally for about a half a mile and it went off. Has this happened to anyone? i only have about 2200 miles on it
get it scanned. otherwise no one can help. can be something as simple as you got gas and didn't screw on the cap tightly. can be anything. but without knowing the code no one can give you any useable info.
I had almost the same issue....i shifted remotely hard from first to second with traction control off...CEL came on for about 2 seconds so i imediatly got off the throttle and havent seen it happen again since....car had no codes from it either. odd if you ask me quick on and off
