Clutches
Clutches
Was talking to someone from Bully about when i need my next clutch
They don't offer a TC version but if im not mistake a SC clutch fits the F35 in the LNF?
I know the Flywheel is 8 bolts on the LNF and 6 on the LSJ but that shouldnt matter
Just wanna double check and make sure
Thanks
Thanks
Thanks
Thanks
Clutchmasters clutch is fine
Just researching my next one
I do beleve they are the same clutch cause im running a LSJ Trans with a LNF clutch in my car
Also believe the Hypersingle is also sold as both a LSJ/LNF
If someone could confirm for sure that would be great
I think if the FW and clutch are used as a pair (like the Exedy) it'd work. The problem comes in mixing and matching pressure plates, disks & flywheels. The LNF FW, (as you know) is mucho different than the lsj. Maven on GMSC has posted on it before IIRC, you could search over there before dropping the $$$.
