Compression test and used oil analysis - Cobalt SS Network
Go Back  Cobalt SS Network > General > 08-10 SS Turbocharged General Discussion
Compression test and used oil analysis >
Old 02-10-2019, 05:23 PM
At 97,979 miles now and wanted to give my engine a bit of a checkup. I ran a compression test today, getting 125, 120, 120, 120. Spark plugs look great at 33k and of course replaced those. I had run Mobil-1 0w-40 Euro for 8,676 miles (2% life left) and the only concern with the oil analysis is fuel dilution. It looks proportional to previous samples, so I'm not feeling Blackstone's concern. They didn't see it causing any wear, but I'll change the oil sooner next time. I have no complaints about the performance. Still pulls like a beast for just having a Trifecta tune and intake.
Solaris99 is offline
Old 02-10-2019, 06:40 PM
Why 0-40 instead of the 5-30? Just curious if it's better.
cobaltss#01 is offline
Old 02-10-2019, 07:13 PM
I had 0w-40 leftover from when I ran it in my BMW. No reason I can't use it in the LNF.
Old 02-11-2019, 04:03 PM
N*gga Kevin
wow, you are murdering that 40w. its shearing down to a 30w but 8k miles I see why. Likely due to the fuel dilution.
are you running rich? Trifecta tune, so probably.
I believe the bearings are aluminum, which is what you are showing here. Not bad for a car with 100k miles to be honest.
Silicon is very low, what intake and filter? those are amazing if you're running a K&N filter. They normally allow silicon parts in the 10+ PPM.
leemanfor is offline
Old 02-11-2019, 05:08 PM
I was using a paper cone element from a Honda S2000.
Old 02-11-2019, 05:14 PM
N*gga Kevin
ah that explains it.
Solaris99
05-03-2013 11:06 PM
leemanfor
10-18-2012 06:11 PM
bri2203
02-02-2012 04:55 PM
umrdyldo
05-12-2011 11:25 PM
Gimpster
11-26-2009 10:41 AM
Quick Reply: Compression test and used oil analysis
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
