DF Goblin from a 2008 SS TC Build Thread
Old 08-31-2018, 10:55 PM
  #126
goblin's Avatar
Sensors have shown up! hope to get on E next week. Thanks again Kevin!!
KMO43 (09-04-2018)
Old 09-01-2018, 07:00 AM
  #127
63 Nova SS's Avatar
You will really like it. You going full e or e47? I've been happy with e47.
Old 09-04-2018, 01:57 PM
  #128
goblin's Avatar
I am going with e47 for now, but I broke the car at the drag strip this Sunday. It seems that my throw out bearing is not working and letting me into gear. I have ordered the GMPP clutch kit which should have the new throwout bearing in it also. should be good to go after installing that I hope.
Old 09-04-2018, 02:39 PM
  #129
KMO43's Avatar
This has been a really interesting project to tune. The data is completely different because of the lower weight. It holds 23psi till redline bo problem! I actually thought it had a different turbo for a bit.
Old 09-04-2018, 03:58 PM
  #130
63 Nova SS's Avatar
E47 with 1600 lbs and big tires would be a blast.
Old 09-19-2018, 09:50 AM
  #131
goblin's Avatar
Facebook Post
went to this event and won the whole thing. we begin tuning in the E47 this week!! I can't wait to see what this thing does then.
Old 09-21-2018, 04:10 PM
  #132
goblin's Avatar
All I can say is WOW! this thing has come alive running on E47. we did a little 60-100 2 tunes ago and it only took 3.542 seconds. I will run it again once we are done tuning it on E47.
Old 09-21-2018, 05:35 PM
  #133
63 Nova SS's Avatar
Nice! E47 really wakes it up. I've done sub 4.0 on my cobalt on e47, basically stock turbo.
Old 09-24-2018, 04:11 PM
  #134
goblin's Avatar
so I lost in the finals at the track last night because they re-glued the track (some big cars had grudge races) while our cars cooled down. after they glued that thing down I could not keep my car in gear. I would spin off the line in first and then when it hooked it would pop out of gear?? this happen to anyone else?
Old 09-26-2018, 08:52 PM
  #135
cluelessk's Avatar
My fifth gear does that after a quick high speed ham fisted shift.
Stays in gear on decel and next to no load. But even just slowly adding load it'll pop out of gear real quick. Can hold in gear with no issues.
Old 09-27-2018, 04:19 PM
  #136
goblin's Avatar
I didn't try holding it in gear. next time I go I will try it.
Old 09-27-2018, 04:49 PM
  #137
goblin's Avatar
that is just wrong, I can't bring myself to run an auto. lol Maybe it is time to throw in a LSD transmission.
Old 09-27-2018, 05:49 PM
  #138
cluelessk's Avatar
Originally Posted by HGT
I would first check your cable adjustment but don't try to hold it in gear. If it is worn syncro's and pops out with pressure on it there will be expensive noises to follow. Mainly disintegrating syncro teeth. As light as that is I would run an auto.
I don't do it regularly it was just part of figuring out the issue.
Also don't go auto. Turns it from a super fun track car to a strictly drag/ half mile car.
Old 10-01-2018, 07:46 AM
  #139
jdbaugh1's Avatar
Like others have said, if you plan on doing anything else with this other than drag racing I would highly recommend against going auto as well. I know for a fact you don't want your transmission shifting around during an autocross run and I would imaging the same would be true for track driving at times. I just don't think it would keep up well with rapid deceleration followed by acceleration or circumstances where you want to hold high RPM, through a corner, with low throttle/low load. As you said I would agree with considering an LSD transmission.
Old 10-08-2018, 10:33 AM
  #140
goblin's Avatar
this is first and foremost an autox car so I will be keeping the standard. it has not slipped out of gear again so I think the answer is just stay off the glued tracks. lol
Old 10-23-2018, 12:40 PM
  #141
goblin's Avatar
we just ran our first autox with the tires this weekend. only problem is that it rained saturday (we still ran them) and on sunday it was 47* F so getting them to fire up only happened on my last 2 runs or so. now with that said, OMG this thing can turn violently. I was .5 seconds behind fastest car of the day which is a guy in a full modded vet that took 4th at nationals last year. He drove to MS from TN to run our event. I was averaging a 1 - 1.5 seconds decrease every lap as I got comfortable and we made adjustments on the car.
I made my first adjustments which was to soften the rear. I am on 4 clicks off of full soft, plan on working on from end next year. tire pressure was 12lbs in front (no rolling) and 14 lbs in rear. can't wait to see what happens on a 90* day.
File Type: mov
jdbaugh1 (10-23-2018)
Old 10-23-2018, 12:52 PM
  #142
jdbaugh1's Avatar
Any vids of this thing autox'ing
crasycowi
Canadian North East
45
06-04-2013 01:36 AM
TonyWest
03-26-2012 02:53 PM
CMVsst2010
03-22-2010 06:48 PM
metroplex
24
04-19-2009 12:47 PM
Quick Reply: DF Goblin from a 2008 SS TC Build Thread
