Did something bad to my '09 TC Engine
Remember to have all spark plugs out so the motor spins more freely and always use a charged battery to test with. Also, you will get different results if you test on a warm motor, so doing it cold would explain a lower number. Like leemanfor said, all cylinder readings should be near each other.
get rid of that original battery. Ive been stuck many of times in a parking lot because the damn thing died in 30 mins because a stupid radar detector was plugged in. Retarded how bad the stock battery is. I got an everlast Gold, and I havent worried about my car being dead over the weekend for 2 years. Literally if I didnt start the car saturday and sunday, it wouldnt run by monday. was like that since day 1.
138 is a good number. hopefully the rest match. or.... hopefully one doesnt match so you find your problem lol.
Okay, so the finally tally for the cylinder compression is"
1: 150
2: 141
3: 153
4: 147
They all seem pretty close, I might pull the valve cover next.
1: 150
2: 141
3: 153
4: 147
Okay, got the valve cover off, found my answer. I snapped off the valve lash adjusters on the exhaust-side of cylinder #2.
I'll get two new lash adjusters and get her running again.
#36
Okay, I finally had the time to finish this job up. I replaced the two busted valve lash adjusters, got it all back together and started right up on the first try. I cleared the CELs and went for a little test drive. Everything seems to be running well. I have the tune off at the moment and I didn't rev it above 3250RPM for now. I'll be changing the oil a little later today.
Thanks for everyone's help!!!!
#41
Thanks, this is a good idea. I put some oil to the side from the oil change until I can find where the heck I put my spare Blackstone containers. Hopefully there won't be anything bad in it.
#42
If anyone was interested, after many months I finally got the oil sample back from when this happened sent out to Blackstone and got the report back. Everything is looking fantastic. I got really lucky with this one.
#44
#47
Yeah the speedo needle is super laggy. Put your mph/kph up on your RPD and you can see a huge difference in speed. I never look at the needle anymore its much more distracting than a quick glance over to RPD.
#49
Nothin Stock
im pretty sure you missed 3rd and hit 2nd, it happened to me be4 and the dealer had to replace the head due to little nicks on the cam shafts etc. glad mine was warrantied tho
