E47 quistion
E47 quistion
Hello everyone, I recently just purchased 2010 cobalt SS. The person I bought it from said it was tuned for E47, just simply mix 91-E85 equal parts and all is good. My question is there is a station that sells E50 at the pump. Could I use this instead of mixing?
2nd question, If using the E50 is okay, could I use E55?
You probably would be ok with e50, and e55 wouldn't be the end of the world. Your fuel trims would be off but not horrible, just stick with either mixing e85 and pump or run e50. The best idea is to get hptuners and log the car on e47 and then on e50 to compare.
Originally Posted by 05duramax
he said it was tune by trifecta, could changes be made with HPtuners or would the ECM be locked by trifecta
You can still log the car with hptuners, you just wont be able to make any adjustments to the tune file. You would need to get a trifecta cable and get a hold of the stock file from trifecta (which I recommend no matter what your plans for the car are)
What matters more than anything, depending on how much timing and such that the trifecta tune has, Is E content in the e85 that you are mixing. I test it every time I get fuel.
If you are counting on it being1/2 e-85 and 1/2 premium, to give you 97octane gas, and the e-85 is actually e-75, then you can get knock due to lower octane.
I'd say the only issue with his situation is the fact that he's running a Trifecta tune.
I'm in-between two stations and one consistently tests at 60% and the other is closer to 55%
Kind of shitty really. Makes me want to invest in an ethanol content sensor
I didn't have any KR running e85 and regular at 22* there is a point on these engines where the ethanol content really doesn't matter just helps with cylinder cooling. I agree the biggest issue is trifecta
I have tested e-85 here and in between 85% tests I have seen it drop to 75% in the middle of summer. Must have been a winter mix truck that delivered (old fuel). You go from e47 to e42 with 85% mix to 75%. May not be a huge deal but I always try and keep it at 47, which may mean I actually mix 6gallons of e to 4.5 gas to keep 47% ratio on the e75.
Would love to have straight e so that I can use all 93 to mix with it.
he gave me the cable with the car. how do I go about getting the stock tune? Also he had done some mods to the car which includes..
at 42,000 miles the motor got rebuilt which included-
-headgasket
-ARP headstuds
-shift cables
-135# opel injectors
-chain tensioner
-upgraded valve seals
-rods and bearings
-pistons and rings
-turbo oil and water lines
-zzp intercooler
-zzp charge pipes
-aftermarket FORGED diverter
-3inch downpipe
-3inch straight pipe with resonator
-k&n typhoon cold air intake system
-trifecta E47
-GM stage 1 Bosch sensors
-zzp billet motor and trans mount
-5speed short throw shifter, weighted shift knob
-stage 1 clutch
-brembo brakes, drilled and slotted rotors
-zzp pillar with RPD and glowshift boost gauge
-headgasket
-ARP headstuds
-shift cables
-chain tensioner
-rods and bearings
-pistons and rings
-zzp intercooler
-zzp charge pipes
-3inch downpipe
-trifecta E47
-stage 1 clutch
Or you can buy a new ecu with a tune supporting your mods from zzp and replace the old one.
well, I'm going to be getting my car dyno tune on Wednesday by ZZP. Anything I should before I go in? I've already changed the oil and put a new O2 sensor in.
