Front TC rotors
Hey I have been looking with no luck on finding a how to for the front brakes and rotors for the 08-10 SS. Basically I'm needing the torque specs. Sorry if this seems dumb as soon as I get pointed in the right direction i'll delete the thread. Thanks
I think their is a how to but then again it may be for the lsj.
Brake Caliper Bleeder Valve - Front With RPO LNF
14 N·m 124 lb in Brake Caliper Bleeder Valve - Front Without RPO LNF 11 N·m 97 lb in Brake Caliper Bleeder Valve - Rear 11 N·m 97 lb in Brake Caliper Bolt - With RPO LNF 130 N·m 96 lb ft Brake Caliper Bracket Bolt 115 N·m 85 lb ft Brake Caliper Guide Pin Bolt 34 N·m 25 lb ft Brake Hose Fitting Bolt - Front With RPO LNF 40 N·m 30 lb ft Brake Hose Fitting Bolt - Front Without RPO LNF 48 N·m 35 lb ft Brake Hose Fitting Bolt - Rear 48 N·m 35 lb ft |
