G85/lsd
How do I find out if I have LSD on my 2010 SS?
Its in the trunk, lift up the carpet and on the driverside there is tag with a bunch of codes
There are numerous ways. Easiest way is looking under your trunk liner, on the left side, you will see a sticker with a bunch of codes on it.... Just have to look for "G85" and you're golden.
Another way you can tell is if both your front tires are off the ground (jacked up), spin one tire, if the opposite tire spins the same way, you have an LSD. If it spins the opposite way, you don't. Good luck! |
dump the clutch see if 1 wheel mark or 2
Originally Posted by carstedt
(Post 6712995)
If you can see the label on the top of the trans it also has LSD on it if it has one. The trunk label is the easiest, but only the tire turning is 100% accurate.
Originally Posted by Derkachenko
(Post 6712970)
2010 'Z49' Cobalt SS = all have LSD There were no factory options for 2010 Canadian destined SS's; The only factory option for USA destined 2010 SS's was the LSD. fair enough? |
...drive it
You can also run your vin through this website:
Comprehensive Chevrolet, Saturn, GMC, Hummer, Cadillac, Buick, Oldsmobile, Pontiac, Geo, Dodge, Plymouth, Jeep, Chrysler, Ford, Lincoln, Mercury, Mazda Truck, Mercedes VIN Decoder And see if your car has the RPO code G85 for the LSD. |
1 Attachment(s)
(Post 6712995)
That what I was going to say lol |
