gms1 dyno numbers?
it's right on CED site
Cobalt 2008-2010 HP & Torque ratings:
280HP @ 4,700 RPM
320 lb,-ft of torque @ 4,300 RPM
Kit disables "learn down feature"
This performance upgrade maintains no-lift shift feature on Cobalts and HHR's and adds it for the Solstice/Sky.
Note:
Solstice SKY HP & Torque ratings:
290HP @ 5,200 RPM
MT 340 lb,-ft of torque @ 3,600 RPM
AT 325 lb,-ft of torque @ 3,600 RPM
HHR HP & Torque ratings:
290HP @ 5,200 RPM
MT 315 lb,-ft of torque @ 4,800
AT 315 lb,-ft of torque @ 4,800
also OP needs to keep in mind that those numbers are crank HP numbers advertised... not the dyno numbers at the wheels we are posting. so the numbers given by some members are pretty close to the driveline loss estimates.
Is the higher peak torque from a small displacement engine with a turbo like the K04 really a surprise? Those are just peak numbers. The HP is so much lower because the torque is relatively short lived.
nope,the hhr ss has the same flatten upper cp. i use to own two of them,now we are down to one.
also you have to take in account where you live. down here living next to the gulf at/below sea level, we will read higher than someone in denver, as an example. that's why royal purple raceway is considered one of the faster tracks by nhra because of the sea level.
#36
Winters in Colorado are cold but sunny so the road surface is mostly dry; snow melts away in a day or two so 359hp is no problem. In fact, on Sunday at the local road track I'll be on my E85 tune
If not I'm probably making 400whp yay lol
#37
ah that could be it. i remember hearing something about the intake system. always assumed the squished upper charge pipe would fall into that category.
