GMS1 users
#76
Originally Posted by ECaulk
Not sure if carb cleaner will eat through it. Powells costs what it does because it works and is quality parts. Other baffled systems may help but they're not going to remove the oil as well.
ThoR294 (03-08-2017)
#85
pick up my v3 already u butt
#86
How long depends on how good of a job you want to do. You can do it all in an hour, but it's not going to be worth it doing it that fast. I spent about 45m-1hr per cylinder when I did mine, but I took my sweet ass time trying to make it as clean as possible.
#87
or
BG Gasoline Direct Injection Cleaner.
This is a similar process for our car.
http://www.will-son.com/docs/Direct_..._Procedure.pdf
#88
GM Top End Cleaner
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
or
or
#89
Using what cleaners? Don't want to ram carb cleaner in there just to find out it wasn't the right one to use lol. Probably going to end up going this route. It's the most cost effective and I can do it on a weekend. Now to protect oil from getting back in? What kinda catch cans do you recommend? Not using powells system solely because it costs a small fortune.
I would love to help you with the catch can question but I don't run one myself. Powell's is the best, hands down.
#90
Originally Posted by T-Man
I don't recall what brand of cleaner(s) I used but the whole process was rather simple. I recommend some good picks, nylon brushes and a rifle cleaning kit. I would also suggest rigging up a suction device you can put into the port before, during and after to ensure you don't miss any of the crap you will no doubt remove.
#92
Originally Posted by Hemphog
You'll want to check out Wangspeed's posts then for more racecar which will lead you to Powell...did your car come with spherical bushings?
Thanks to those for clarification on GMS1 and learn down as there were prior questionables.
Who ended up with the Wang car anyway?
#94
I bent my stock endlinks, went with moog and they handled the work so far. Powell recommends adjustable but depends on $. You're off with some goodies then.
#95
I did what T-man did but let mine soak overnight since it was parked for the year.
Powell makes good stuff and I try to buy as much from him as I can because he has been a big supporter. Still need to get some cut front strut housing to slip my koni's in. I also went with the adjustable end links but haven't played with them yet.
#97
Honestly, I'm just not that concerned with it. If I pushed the car hard on a road course or track on a consistent basis, sure.
I'm sure most would call me crazy but it's not that hard to just treat the valve cleaning like general maintenance.
#98
There are things you can do to help keep the valves cleaner. Run a low ash oil, use top tier fuel (again less ash), limit long idling time, keep the RPMs above 2350 while cruising, and give it the "Italian" tune-up (drive the car like it was designed to be driven at the track high rpms for extended periods of time. All that will help limit the build up, but you'll still have to clean some off.
The catch cans just don't work on our cars, the oil is a mist not splashes of oil.
#99
