Guage pod with RPD?
Is there any gauge pod that works with the RPD?
I've been asking this question for half a year or so and I don't think there is. The un-customizable nature of the pages on the RPD are it's only real downfall in my mind. If there's even one thing on another page I want to see, I have to switch pages, and can't see the combo I want. I'd like to put in other gauges in addition to the RPD (like an Interceptor for instance), but no gauge pod exists to do that.
X2 Let's get a vendor going on this!!! :)
BTW, isn't it spelled "Gauge? :lol: |
Originally Posted by JPizzle
(Post 4457061)
BTW, isn't it spelled "Gauge? :lol: https://www.cobaltss.net/forums/zz-performance-99/gauge-pod-w-rpd-slot-168254/ https://www.cobaltss.net/forums/appearance-48/rpd-gauge-pod-185188/ Bugged ZZP about it several times, on the forum and on their website. No response back. I hear they do good work with gauge pillars/pods too, so it's a bit of a disappointment. Yup. |
Now that all new TC's come standard with the Rpd it would be a good idea for a vendor to make this!:cssNET:
Just buy the ZZP pillar and relocate your RPD..? Prob would mount nicely right behind steeringwheel where the redlines have there boost gauge.
Since that is easy to do:lol::lol::lol:
But it would look nice, but that is a lot of work. A vendor would have no problem doing this if they had a car to test it on |
I think the RPD has some wierd flanges that would keep you from doing that unless you wanted to start cutting away at it...
I thought about going the other way with it though... maybe doing a gauge mounted on the steering column or one of those instrument panel integrated ones. |
I will be attempting to mount an RPD to my ZZP triple gauge pod in about 2 weeks. I'm doing the conversion from my reg boost gauge to RPD, as well as adding a mechanical boost gauge. I know the mounts on the RPD are COMPLETELY different, so I will write up a how-to (if I can get it to work) on how to mount the RPD to a regular pillar gauge pod, for those who want to do the switch that is, or want a new pillar pod.
If you have the RPD why do you need more gauges??
Originally Posted by BYT*SS*TURBO
(Post 4458550)
It has Boost and Wideband, typical things people add gauges for.
(Post 4458608)
You can't see both boost gauge and wideband (or any two things at once). You have to keep flipping around pages for them. Sucks when you're trying to troubleshoot. I'd like to also make sure I'm not knocking (RPD version doesn't work well if at all) and have the ability to read/clear CELs. Something like a Dashdaq is expensive overkill for what I need and I don't like the unfinished suction cup mounted appearance of it. Just looking for a little more functionality. If Vince or somebody created RPD software that would allow additional functionality I would be happy with that too. |
Originally Posted by Stamina
(Post 4458657)
Originally Posted by Shez
(Post 4458671)
Sorry to sound like a noob but what gauge shows that?
They are able to read it off the car's databus and in most cases allow you to reset/erase the codes if you'd like too. |
A dashhawk would cost as much as 2 gauges and a pod. And wouldn't have the ricey pillar pod too :)
(Post 4458550)
So I can see more than one thing at a time. My RPD will mainly have my A/F on it, and I also don't trust electronic boost gauges. I like mechanical better (as they read a lot more accurate than electric). There's also some things I want to see that the RPD doesn't show. |
(Post 4458677)
Pretty much any non-analog aftermarket solution to my knowledge. Aeroforce Interceptor, Dashdaq, Dashhawk, PLX gauges, etc.
Come on Vendors... Let's get this shit going!!!! :)
(Post 4458793)
Ohh, alright. I figured that. I thought you meant there was like a circular gauge that showed that. That's why I was confused.
could one use multiple plx's, or is the only dual gauge setup the interceptor dual gauge.
Originally Posted by importkiller
(Post 4461406)
Two week bump
someone with extra money on hand take the RPD pillar and a dual or triple gauge pod pillar, cut the two in half and make a frankenstein pillar. then wrap it in Carbon Fiber or make a mold with it.... seems simple enough...
Originally Posted by CudaJoe
(Post 4500541)
