Helppppp!
I keep throwing a P2261 CEL and thats the only one. IDK whats causing it, i regreased my forge valve and that didnt help. I checked the vacuum tank and it seems ok Ive read that service bulletin 100 times but ive never read about anyone actually replacing the vacuum tank, they just quit responding to there threads on how they fixed it. Its getting annoying and only pops up every 2-3 weeks.
Could you hear it fluttering I assume? mine never flutters except at a cold start but I was told thats normal.
Depends which spring you were using, but probably not. Assuming you used the spring that comes in it. Green, I think? Let me go check.
edit yellow one is sitting on my bench in a bag, so the green one must be the one that comes in it. If you're on Green it shouldn't change your tune.
So Forge BPV test failed with green spring and passed with yellow spring in. Found it had a broken oring/gasket.
PIC
The benefit of no diaphragm to go bad. I don't have an issue servicing my forge once a year. After owning a B model Cat as many years as I did just the mention of the word diaphragm makes my entire body shiver. #%$@%$# transfer pump diaphragms would not make it through the winter and would tear at the worst times in the worst places. !@#$ that!
yes, I know, the LNF doesn't have the same history as the B Model JWAC, but still!
Yea thats the reason I got it, forge responded to my email and there sending me a new oring and green spring. I did another pull today and still good...I dont like beating on my car this much but I wanna make sure thats what it is. lol
