How are the high mileage SS/TC's holding up
Old 12-18-2013, 11:41 AM
  #151
user 72239's Avatar
Originally Posted by Tomtwtwtw
Please check your sway bar end links before you replace your hubs. I got the grinding sound making right turns and this fixed it. Or, if you're going to replace the axles and hubs anyway, spend an extra 50 bucks on a pair of Moog end links and swap them out while you're in there. Once I removed my stock ones I could hear nasty sounds from them just by rotating the bolts. They were so done.
Already replaced them with Moog endlinks about 2 years ago.
Old 12-18-2013, 12:32 PM
  #152
emiller's Avatar
80k. New o2 sensor about a month ago. Rear brakes around 20k under warranty. That's it for me.
Old 12-18-2013, 03:49 PM
  #153
Tomtwtwtw's Avatar
I have to ask - have you been re-greasing them regularly? Sucks if it is indeed your hub that is done, but most of the time it always seems to be something else causing the issue. Suspension, off-balance wheel, etc. Good luck either way, hopefully you get it fixed without TOO much trouble.
Old 12-18-2013, 03:59 PM
  #154
Tomtwtwtw's Avatar
Oh yeah, I have this too, also right at 20k My driver's rear inside pad was metal-on-metal and the outside pad was practically new. Passenger side was wearing even. Here I am 60k later and my rear pads are *maybe* 50% gone. Just goes to show a properly working set of rear pads should last over 100k on this car. A shame so many were screwed up from the factory.
Old 12-18-2013, 04:23 PM
  #155
matthewj182's Avatar
113k on my 06 SS SC alternator just went out but that's about the only major problem besides regular stuff.
Old 12-18-2013, 04:56 PM
  #156
ssyellow's Avatar
What pads did you go with? I just changed my rears out for OEM blank rotors and Hawk HPS pads, appears to be a winning combo for others.
Old 12-18-2013, 05:03 PM
  #157
Tomtwtwtw's Avatar
It was a warranty fix by the dealer, so I assume OEM. I did my own front brakes at 50k with OEM as well. I'm doing more highway now so I may not need new fronts till 110-120k at this pace. I checked them out last weekend when I did my front suspension and the pads are still pretty thick.
Old 12-18-2013, 07:15 PM
  #158
emiller's Avatar
Mine were stock pads and stock rotors. Actually mine didn't wear uneven there was plenty of pad left at 20k. They were grinding and it looked like someone took a chisel and carved out some pretty deep grooves on both inner pads. I'd guess that something got caught in there since there isn't a back plate.
Old 12-18-2013, 08:20 PM
  #159
ssyellow's Avatar
Interesting. My older TC had this issue and warranty took care of it, body warranty was out on my current one so I did it myself.
Inner pad was gone and the outer had tons of life left. Shout out to GM for not making a recall about this hah.
Old 12-18-2013, 08:31 PM
  #160
SLRdohc's Avatar
update, at 64k now and I've had to replace the Passenger Seat Belt airbag sensor.
How much was that? Im at about the same miles (little less) with the airbag issue...
Old 12-18-2013, 10:00 PM
  #161
BigOD89's Avatar
Originally Posted by umrdyldo
Try new plugs, but there is that good chance that the valves are gunked up.
Good luck.
Yeah i have new plugs on the way I'm hoping that is all I figure that it is because I took them out to check them and they are completely shot they look horrible.
Old 12-19-2013, 04:45 AM
  #162
GreenySC2's Avatar
93,035mi as I sit here at work.. running strong...
Granted I bought it used with like 78k the only previous owner had some transmission stuff, flywheel I think replaced under warranty... the only warranty work I had done was the left axle and hub... then my warranty went poof because I didn't extend it....
Outside of crappy tires the previous owner put on resulting in a gash in one and a side wall puncture in the other all is well in my world
Old 12-19-2013, 08:19 AM
  #163
user 72239's Avatar
540 some odd dollars at the dealer.
and Tom, I haven't ever greased them. the thing is i feel the grinding in my shifter when taking a left hand turn and then it goes away when it straightens out.
Old 12-25-2013, 03:51 PM
  #164
ORLANDO09SSCOBALT's Avatar
Originally Posted by imacho2
i have 38,000 on mine now. bought it a year ago. just replaced the rear brake pads 2 weeks ago. no issues. not driven hard. just an all around fun car to have.
I have 134,000 miles. 09 SS Turbo Victory Red...Blew #1 piston ring at 84,000...engine rebuilt under powertain...blew 5th gear syncro at 98,000...new tranny installed under powertrain...limited slip as original...New tranny 2nd gear syncro went at 128,000...GM said get lost....Turbo fell apart at 134,000 and damaged the engine...(Nobody ever said the are good for 100-130,000 miles at the deakership! Just ordered new LDK from ZZP...will have installed next week...still dealing with the dealer as far as the tranny is conerned...I told the tech that something was wrong with the new tranny as soon as it was installed...tech refused to test drive the car...just went for a ride an said it seems ok to him...Now I know I was correct. I have been driving a stick for 42years..I don't race and I don't miss and grind gears. I'll let you guys know about the LDK and how the dealer deals with the tranny after the new year. I still love the car...it's my every day car.
also have 07 GM Saturn Aura 74,00..no major problems
07 GM Saturn Vue..Redline..72,000..no major issues..torque converter replaced under bumper to bumper warranty
I'm sticking to GM for now..but the future depends on tranny issue.
Old 12-26-2013, 09:10 AM
  #165
umrdyldo's Avatar
What kind of power were you running before you had issues?
Old 12-30-2013, 02:04 PM
  #166
NickD's Avatar
Just turned 60k miles on my '09. I've had it since new. I daily drive it through NJ traffic. For the last 20k miles it's had basic bolt ons and running a 22lb trifecta tune. I've tracked the car every season for the past 3 years (drag and road course) and it's winter driven daily with a set of snow tires. I can't really talk about brake wear since I am constantly swapping brake rotors and pads around depending on a number of things but I did have to do the original rear pads and rotors at aorund 20k miles, but the replacements (factory pads, centric rotors) have gone 40k miles and I don't swap those for track days. So far the problems I've had with the car is the evaporiatve purge valve failed, my shift linkage clamp failed and I sheered off two valve lash adjusters. I do all my own work so I spent <$100 in repairs to date.
Old 12-30-2013, 04:45 PM
  #167
Tomtwtwtw's Avatar
On a side note, is there anything more to replacing the lash adjusters than popping off the cam cover, plucking the old ones out and dropping the new ones in? I get the occasional valve train tapping and wouldn't be surprised if I have some worn ones up in there, if not completely gone yet (car still drives fine).
Old 12-30-2013, 08:51 PM
  #168
NickD's Avatar
The cam is in the way and some of the adjusters may be compressed depending on the position of the valves. What I did was loosen my cam which gives access the cylinders 2, 3 and 4. However, I don't think you'll be able to access the adjusters in cylinder 1 using this method.
Old 12-31-2013, 12:33 AM
  #169
EFoxwell's Avatar
I'm closing in on 17k miles. She's getting up there.
Old 12-31-2013, 05:18 PM
  #170
I wish mine still had that kinda mileage
Old 01-01-2014, 01:07 PM
  #171
Never on a Dyno....tuned to 24lbs.....only other add on was the Modern performance intercooler. Again, I do not race from the line. On the highway, that's a different story.
Still waiting for the New engine from ZZP to arrive as of 1/1/2014 from ZZP. There is so much info that is not known about the new engine. It says it's LDK/LHU...cannot find what the actual HP/Torque is...220-250-270??????
Many say the turbo is what make the difference. I already purchased from ZZP and had a new K4 Turbo installed for the original engine...and then found that the engine was damaged when the Turbo fell apart.
Purchased the new engine with the turbo already installed.
May sell the old engine after having it rebuilt or have it ready for the future if I blow this one apart. Only time will tell.
Putting out this money still saves me from new car payments..so I'm good so far.
Old 01-05-2014, 05:36 PM
  #172
murderedout09's Avatar
Bought my 09 brand new. Just rolled 85k last week.
I've done brakes twice, cam actuator solinoids in/ex, and I broke the ball linkage where the shift cable ties on to the ball on the shifter.
Other then that, it's been a great car, and I still enjoy driving it.
Old 01-05-2014, 05:41 PM
  #173
BlackielawlessSS's Avatar
99k on mine still runs great and pulls hard.
Old 01-05-2014, 05:57 PM
  #174
aaol1's Avatar
got an 09 TC with 80 ish clicks on it, KM that is. rear brakes and rotors( like everyone else) shifter cables, hand brake adjustments, injector on #3, spark plugs....worst was injector on #3, guy messed it up fixing it and messed up the seals and stuff on all other injectors somehow, had to change all of em...1500$ fix, all under warranty still loving the car though, no issues for the last 4-5 months
Old 01-06-2014, 10:15 AM
  #175
CudaJoe's Avatar
2009 sedan, 76k and still okay. left turn signal just went out.
Quick Reply: How are the high mileage SS/TC's holding up
