How are the high mileage SS/TC's holding up - Page 11 - Cobalt SS Network
Go Back  Cobalt SS Network > General > 08-10 SS Turbocharged General Discussion
How are the high mileage SS/TC's holding up >
Old 10-04-2018, 10:39 PM
  #251
Yep, Royce is correct. NLS 2-3 after doing it a few miles back with no issues and this time injector 4 stuck open and tach went past 6300 and then started misfiring bad running in the 9-10 AFR range and didn't sound healthy at all. Diesel truck. Pulled Cyl 4 plug and found oil and then started pouring fuel (fuel rail was still pressurized I guess and was draining into the cyl). So I let it sit overnight with plugs out and then towed it home. Compression tested fine but it's had blowby for quite a while now, powell separator won't drainback. Dipstick has a bit of pressure coming out and that's causing it to not drain. So LDK swap it is. Keeping the current clutch cause it's only got ~10k on it. New flywheel & PP bolts and trans fluid since I'm going through all the effort. And some new O2 housing gaskets. It'll be done quick. Need the garage space for other things.
ThePanduuh is offline
Old 10-05-2018, 03:40 PM
  #252
Im around 104,000 miles in my tc sedan. Cars feels the same as it did at 80k miles. Original motor, clutch, turbo. Tuned on 24 psi since 50kish miles. I need to change the brake fluid next time I do a brake job. I remember the rear calipers 2 years back felt like they were difficult to compress on the passenger side. Major clunking still over light bumps in the road. I knew my CABs were done long ago but not enough interest to replace. The BPV is sounding a little silly lately but still holding 24 psi at WOT. Changed the filter with a clean K&N cone. The fuel trims slightly wild but not exceeding the limits. (+2.3 to +6.0 LTFT).
My car needs a real good cleaning. The K&N intake heat shield is rusting, the black coating is coming off at a spot that clearly collects water during hard rainstorms. Theres a nail in my rear passenger Dunlop Direzza Z2 tire but the life of the tires are pretty much done so not worried. This was their last season. Back on DWS tires till I can replace the summer tires next year.
CudaJoe is offline
Old 10-07-2018, 01:11 PM
  #253
I'll pass 162k tomorrow on the drive to work. Currently sitting at 161,99x miles. Oil change coming today.
I need to get an alignment when I get new tires in the next month or two. Trying to decide whether to get all-seasons or a set of dedicated winters.
MINIz guy is offline
Old 10-07-2018, 02:11 PM
  #254
Having 2 sets of wheels and tires is best. Costs more but you get a better tire for the season and they'll last more seasons.
cluelessk is offline
Old 10-07-2018, 06:20 PM
  #255
That's true. I do a lot of miles so it is best to be safe during my commute. I just don't think it'll snow that much where I'm at, so an all-season may get the job done. It was 80 degrees Fahrenheit today!
Old 01-24-2019, 04:21 PM
  #256
215k 09 lnf
Iíve put my Balt through hell highway miles in Cali. Just recently did my ZZP tune and itís still pulling strong.
phytoPulse is offline
Old 01-24-2019, 06:37 PM
  #257
Should of updated this thread, I have the OPs car. Did a leak down test last weekend, 3-5% leakdown on all cylinders with 119k miles.
ECaulk is offline
Old 01-24-2019, 11:32 PM
  #258
What did he buy, a vw? Can't remember. I wonder if he wishes he would have kept it. I'm setting here at 44600 miles.
63 Nova SS is offline
Old 01-24-2019, 11:34 PM
  #259
Yeah he got a cc, they're a nice car. He got to many tickets with it
Its my daily so i put about 15-18k a year.
ECaulk is offline
Old 01-25-2019, 09:01 AM
  #260
royce777's Avatar
catching my coupe. I have 45,8XX. lol no more miles will be put on it under my ownership
royce777 is offline
Old 01-25-2019, 11:15 AM
  #261
ProfDNS's Avatar
The Royce Museum of Cobalts is now open!
Also, I'm on the cusp of crossing over 200,000KM.
ProfDNS is offline
Old 01-27-2019, 12:17 PM
  #262
117,000 miles and she still holding strong. Have literally replaced everything else on the damn car besides the engine and turbo (knock on wood). No longer my daily anymore so no more 18k a year. My daily 01 nissan maxima actually has some decent high mileage and starts everyday and don't leak anything, 273,000 miles on that old girl.
C0balts5 is offline
Old 01-27-2019, 03:06 PM
  #263
I'll be hitng 100k in the next 2 weeks on my sedan
Snail_SS is offline
Old 01-27-2019, 09:49 PM
  #264
Hopefully your ownership doesn't last much longer. You will get some miles from the joyrides.
Old 01-28-2019, 09:41 AM
  #265
royce777's Avatar
no joy rides unless they have cash in hand. I honestly tell people dont come look at it unless you have cash. Some people get pissed off.
royce777 is offline
Old 01-28-2019, 09:55 AM
  #266
but at the same time if I had 12k cash I'd be dropping that down on a nice used LS3 sedan and paying **** per month for 5 years lol. some museum will hit you up eventually to put the masterpiece in a good home.
Old 01-28-2019, 10:31 AM
  #267
167500. Replaced trans at 110K, not out of need but to put a 4.45 F35 in. Then put in an all forged/built LDK in at 135k due to no compression in 2 cylinders. Broke ring lands and they stayed help perfectly in place like a puzzle piece by the rings. Both rocker panels need replaced. Waiting for warmer weather. Going to try myself, though I cant find anywhere where anyone has done a Cobalt online anywhere to follow along.
cw383 is offline
Old 01-28-2019, 11:07 AM
  #268
royce777's Avatar
12k cash really isnt that much. Its just crazy how shitty the cobalt world is. LSJ prices have dropped terribly and it affect the over market of the clean cars. This is sad to say but im to the point where I am about to trade both my cars in.
royce777 is offline
Old 01-29-2019, 09:37 AM
  #269
I mean when these cars are selling for 6-8k avg yea, 12k is significantly higher than the average. then again, the car is cleaner than all of the 6-8k cars. i don't know anyone looking for a clean cobalt. Luis's car was the last "clean" cobalt I saw sell and it was in rolling shell form so i dont know if it even counts.
Old 01-29-2019, 10:31 AM
  #270
royce777's Avatar
well the biggest factor than no one considers is that those 6-8k cars require 2-3k of maintenance to be done before people can even start to mod and enjoy the cars. nobody takes care of the cars.
royce777 is offline
Old 01-29-2019, 10:49 AM
  #271
you're not wrong. but most people don't look into that nor get far enough into research to see their ghetto catch can and intake do nothing. so the majority of the crowd picking these cars up in this day and age are noobs (not gonna lie that was me). but it's a good learning experience. you're looking for a certain buyer in a market of cheap asses unfortunately. Only few people know how clean it is and how it is absolutely worth the money. Though time adds wear too, coolant, brake fluid probably should be changed.
Old 01-29-2019, 11:44 AM
  #272
royce777's Avatar
dont worry, car is stored in a climate controlled garage and everything is maintained
royce777 is offline
Old 01-29-2019, 12:07 PM
  #273
ProfDNS's Avatar
dont worry, car is stored in a climate controlled garage museum and everything is maintained
Fixed.
ProfDNS is offline
Old 02-07-2019, 04:22 PM
  #274
2009 Cobalt SS/TC, 141,000 Miles on it. Just bought new FE5 suspension because the originals were worn out, had to get new rear calipers as well because the rears were seizing, I could probably use my intake valves getting cleaned. Been running a CAI from K&N and Straight Pipe since I bought it at 26k and within the last 10k miles I've added a ZZP Intercooler, ZZP Lower Charge Pipe, HPT Tune at 24psi and GMS1 sensors, also just bought ZZP Lowering Springs to get rid of the awful wheel gap. It's been a strong car, I definitely haven't been gentle on her and I'm sure with the tune and power it's making now more problems will start to show. The only problem turbo wise currently is a Vacuum leak I have to track down. I do love it, and I don't see myself getting rid of it.
Giggleschits is offline
01-12-2016 01:01 AM
no_ss
10-19-2015 12:58 AM
Slick_Nick
09-28-2015 10:15 PM
09-27-2015 09:53 PM
metroplex
09-27-2015 08:48 AM
Quick Reply: How are the high mileage SS/TC's holding up
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
