I believe we have a problem Houston.....
I'd love that, but I doubt they'd do it.
Still waiting on am email back. I'll agree with you guys though, even with that mod list from the test car 480whp seems way to big a stretch at such a low boost "limit".
480hp on a 71 with stock head and cams is 28psi with ported head and stg2 cams is 25psi. So in tgeir build engine to do 480hp would be the the neighborhood of 28psi+
I understand just giving a reference point for 480hp
No problem
#38
my thoughts are they are essetially operating on the 'honor system' when they ask for the tuned boost level, then say that it was set too high for that turbo;
What would have happened if the OP lied ans said it was set to 23psi(?) - would they have called BS, or accepted the turbo?
I'm all for behind forward and honest;
From both the customer side, and from the side of the business, it is my opinion that when you strip everything else away, the most important thing that either parties have is their word - if any party's word is worthless, well, what's the point in dealing with them.
#40
The ZFRs have a BW warranty I believe
#41
ah good ol ZZP
you could have told them you'd only ran it at 15 psi its entire life and they'd say "thats too much, we run them at 12-13 psi only"
******* shady bullshit.
FWIW, my journal bearing turbo on my STi states max boost at 2.5 bar with their performance thrust bearing. so they can handle quite a bit.
2.5 bar = 36.2594 PSI
Lucky for you, journal bearing turbos are cheap to rebuild.
#42
now, 23 psi is a 2.56 pressure ratio(assuming sea level), im having a hell of a time finding a compressor map, be it ball or journal bearing turbos, that only goes to 2.6 on the pressure ratio.
zzp is full of ****
#48
Idk if it is a change of heart yet. I just reread the email and it says warranty inspection.
Hopefully this gets sorted out right.
I already planned on pulling everything downstream of the turbo to the head for cleaning after this.
#50
