Intercooler finally cracked
Hey guys, after 85k miles the endtanks cracked on the stock intercooler. Wanted to go to with a ZZP but they seem to be sold out at the moment.....what would be your second choice....mpx, hahn, ebay lol. I am leaning towards mpx but heard they're inlets are smaller then stock, dont want to have a leak
Other mods are K&N SRI , ZZP tune, hahn catted downpipe and Mpx catback
I run the mpx catback as well...great exhaust. Ive heard their intercooler has smaller inlet pipes then stock intercooler so i am a lil worried the charge pipes wont fit tight and ill have a leak.
If anyone has an mpx intercooler i would love to know how it it
I just ordered an Mpx intercooler....unfortunately ZZP is out of stock for the next 4 to 6 weeks. One last question....if i wanna upgrade the couplers that go from the upper and lower charge pipes to the intercooler they should be just 2.5" straight couplers correct
...not bent or elbow couplers? And i would put 2 tclamps on each coupler right?
thanks guys
thanks guys
thanks guys
thanks guys
to give you an idea on what bends the couplers would need.... you are not finding generic couplers to fit our cars. ZZP sells these.
https://zzperformance.com/ecotec/int...-couplers.html
Gotcha thanks....wanna keep the stock piping for now so how should i reconnect the stock couplers to the new intercooler? I have to cut the rings right so should i juse 2 tclamps for esch coupler?
if your keeping the stock piping, dont buy new couplers. There are clamps on the stock couplers. Use those to clamp to the intercooler. The rings Im talking about are where the stock couplers attach to the stock piping. There is a clamp for the connection to the intercooler.
If you lift the car and look underneathe, there are two spot where you can access the clamps to loosen and remove them from the intercooler. When I swapped my intercooler, I had a hell of a time because GM had tightened the couplers from some other way where the nut wasnt accessible unless I unbolted alot of the plastic underside lol. In this photo I took, I had already loosened and rotated them into an acceptable position to access them better in the future.
In the red circle is the plactic ring you had to cut off if you want to reused couplers with new piping. Very carefully though as you dont want to put a cut in the coupler...
reused couplers on ZZP hard pipes. T-Clamps to hold them together. You do NOT want to T-clamp a pastic pipe. You will more than likely damage it if its too tight, or pop off the coupler if its too loose.
Thanks for the pics......yea now i remember there being clamps where the charge pipes connect to the intercooler...last time i was down there was when changing the Tmap sensor on the lower charge pipe years ago.....hopefully all goes well with the mpx intercooler install....only issue ive read is the inlet pipes on their intercooler are a lil smaller then stock so hopefully I dont get any leaks
Go it installed very easily surprisingly....that was a perfect right up in the "how to" forum on how to remove the front bumper. The MPx intercooler fit perfect with the stock piping. When i get a lil more $$ would like to do a ZZP upper charge pipe with the upgraded couplers....should fit this intercooler no prob right?
thanks for all the help!
If interested I have an Injen IC upper pipe I bought for my HHR SS, but would not fit unless I modified the air filter
https://www.chevyhhr.net/forums/clas...-cobalt-57872/
