Keyless entry quit working
Old Sep 3, 2011 | 10:38 PM
quickboat's Avatar
Angry Keyless entry quit working
I accidentally went swimming with my keyless remote and although I dried that one out, both remotes quit working. I understand the one getting wet being screwed but why dont either of them work?
TIA
Old Sep 3, 2011 | 10:45 PM
Check the piece on the good one that holds the battery to the board.
if it has separated, go to local hardware store and spend ten bucks and get a soldering iron and attach the piece back to board.
I had the same issue last week. Took me a minute literally.
Goodluck
Old Sep 4, 2011 | 08:16 AM
quickboat's Avatar
Has anyone else had both fobs crap out like this? I think it has to do with a relearn or some thing. My second fob worked perfectly before the first fob took a swim. But now neither? WTH?
Old Sep 4, 2011 | 08:24 AM
ericgt79's Avatar
batteries usually go bad in pairs
Old Sep 4, 2011 | 08:25 AM
ATLsilverSS's Avatar
yes both mine crapped out at the same time and the tpms quit working at the same time also
Old Sep 4, 2011 | 08:37 AM
Intmd83r's Avatar
you can take you FOB to auto store then can see if it works . autozones have the machine around here to test it . my wife has had nothing but problems with her FOB's one of hers unlocks fine and has trobble locking . the other one has trobble unlocking and locks fine ... and my FOB's i have never had a problem with . you can allso try hitting it with contact cleaner
Old Sep 4, 2011 | 09:33 AM
quickboat's Avatar
Thanks guys. I got the one that was wet working again. But the other one (spare) is dead. I tried to solder it. I had the same problem under warrantee about a year ago and they said the fob was replaced. I guess when they re programmed the new warrantee fob my second original fob became obsolete??!!?? So much for having a spare!
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
SSLOW06
Oct 1, 2015 07:21 PM
jmelton327
Sep 26, 2015 10:04 PM
