LDK Swap List
#101
Yeah, a lot of that stuff doesn't come on a long block from zzp and is easily swapped. I was refuted a while back for saying the valve covers are different so it's nice to hear I'm right. I think there's also a hole missing where the wire for the secondary o2 sensor attaches to the side of the head. I think the pump is in the way iirc. Thanks!
#104
lnf
id also like to note that the passenger side engine mount is different. the LNF mount must be used as well as the LNF lower mount bolt that connects to the block. the LHU bolt is slightly longer and the LNF ening mount isn't as thick. and I was able to bolt up my downpipe to the LHU engine using the manifold it came with.
also, the hole for the intake manifold map sensor is slightly smaller. no matter what i tried i couldnt get the map sensor in with the thicker seal that came with the 3 bar map sensor. it fit fine in the LNF manifold. i ended up taking the seal off the map sensor that the lhu engine came with, put it on my 3 bar sensor and it fit.
#105
Well the LNF finally went and I just grabbed a LDK from ZZP along with some other goodies. We are in the final stages of putting her back together and will deff post pics and videos in a few days!
exninja (12-11-2018)
#106
Huh, didn't know there was a thread on this.
Did my LDK/LHU (same thing, mine's A20NFT) on November 17th-18th.
Ordered through Jeff Reiland (mongorat) because ZZP didn't come with opels, hpfp, intake manifold, or throttle body. Jeff's supplier comes with everything to drop in for $2700. I transferred over 1 banjo fitting above upper rad hose and my O2 housing/turbo elbow and that was it. Plug and play.
I thought my slave was bad but it was just the clutch pipe nipple. Now I have a spare slave & clutch pipe that i'll sell. Then my fuel line kicked the bucket, $134 for that local and about 2 hours of swapping that over.
I just got HPTuners this week and I'm getting it tuned for the Opels, looking at 20psi "not breaking things" tune.
Video of me and 06cobaltss/ss doing the swap here:
#107
Video of me and 06cobaltss/ss doing the swap here: https://www.youtube.com/watch?v=PqR331O8BEo
#108
Anyone here running stock LDK/LHU cams? I (and a few others) are experiencing low RPM (<3000ish) <100% airload. So part throttle lower RPM. I have 0 KR past 120% airload past 3500 RPM (basically where it would be super bad to have KR I don't have KR, but where I shouldn't I do). I am wondering if anyone here has this issue.
Stock engine mount, stock upper transmission mount, OTTP front and rear transmission mount. Stock LNF clutch and flywheel.
#110
#111
Car cranks but wont start
I purchased a LDK long block from ZZPerformance for my cobalt ss had it installed, it cranks but wont start! I notice the alarm is not working, does anybody knows why it wont start? Please help
#113
A friend of mine installed it!! I thought because the alarm is not working now, it must have something to do with it! Everything seems to be back where its supposed to be!! It has spark, fuel lines are good! Its just weird! It cranks but wont tired up
#114
Those that are still active here and remember enough about the swap:
LNF 3 bar MAP sensor won't fit into LDK intake manifold without boring it out, this is known
what did you do to make it fit? oil, pressure, hopes and dreams?
I personally ran the green o ring that came included with the new sensor but it fit loose. Recently I have switched over to a 3 bar o ring that will fit the intake manifold, a slightly smaller outer diameter than the LNF 3 bar O ring I guess.
Thoughts?
Thoughts?
#115
Thoughts?
Thoughts?
#116
Thoughts?
Thoughts?
#117
Thoughts?
Thoughts?
#118
Isn't the "LNF" 3 bar map OD the same as the LDK map, but the LNF uses fatter o-ring anyways?
The only difference in the IM's is the MAP sensor provision (afaik). Even if you have the MAP slope and offset wrong in the tune it should start fine, it would just run like poop.
Anyone have issues with K04 hitting the firewall when using stock LDK/LHU exhaust manifold and rotated rear trans mount? This is what mine looks like.
https://imgur.com/khfdr30
BoostedCobalt22
09-10-2008 01:49 PM
