LNF valve gunk pics
I learned so much today. I'll post tomorrow some tips in the main gunk thread.
Got all done. Started car. Choke girgle backfire. CEL. ESC. Traction control. I about cried. Took forever to connect Torque to car. Turned out it was pedal and tps code. I clipped the plug but not the gray tab. It had Popped out. All better. She purrs and throttle response and horsepower seems to be better.
Now to save up for Powell oil separator. Thanks for the help guys
PS I prefer undoing the 4 TB bolts and leaving it in place, and not screwing with the connector or the inlet tube. Normally they burp and run. My job this weekend took a little time to get woken up on restart. Engine must have thought "where is all this inlet air coming from?".
this works and for sure, Wired is right, go through the vacuum boost port , it is the largest remove the hose and nipple 19 mm wrench
#41
COKING IN DIRECT INJECTION ENGINES? - FerrariChat.com
and please check out valve gunk thread by wired and the pcv upgrade thread tx
http://www.moderncamaro.com/forum/ge...i-engines.html
#43
It needs more/ The oil seperator we supply has two check valves in addition, and a drain back feature along with mesh screen and fine paper filters. AN fittings and lines. Pretty decent upgrade, ( back slap lol) I think.
solstice /sky LNF
stock style seperator biscuits
LSJ/Redline
LSJ Cobalt
LNF Cobalt
#44
John, my new kit ( deer damage killed old one ) came with an extra check valve fitting. I had emailed the instructions to the body shop and they left the said fitting off, and I cant locate the instructions I sent them. I know my original Powell PCV setup didnt use this. What does it do, and where does it go? Sorry to go off subject slightly, but it may be beneficial info while discussing your setup. I went from a teaspoon of oil each time I removed my intake tract to none at all with your PCV system.
#45
You have proclassic hose with full flow adaptor fittings
http://www.russellperformance.com/mi.../tech_page.pdf
