Loud fluttering noise when i shift...5 psi boost
So I have been having this same problem for about a month now. I have an 09 ss. Some days my car starts and other days it wont start. Sometimes when I shift my car makes this loud fluttering noise and my boost wont go past 5. I have taken it to the dealer five times now and they claim that nothing is wrong with the car. They couldnt find anything. I find this really hard to believe and I have no clue what the hell is wrong with my car. Has anyone else had similar experiences with this, or does anyone know what could be the problem.
would the bypass valve have anything to do with it. Im new to these turbo cars, do you think I have water in my oil or engine. I had an AEM intake
do you think it would be worth it to get the forge bypass valve and replace the stock one. Ive heard that can cause it to flutter also and lose boost
If it was the cold side make sure the radiator bolt sticking straight up is either removed, or put a 1/4" washer between the frame and the bolt to keep it away from the piping. Mine is gone all together, that ***** went right through it.
car is going back to dealer tomorrow.
ya the dealer said the radiator was "sticking out to much" and that caused it to put a hole in my charge piping. As for the starting, i would go out in the morning for work and my car wouldnt start, wouldnt even try to turn over, no clicking or anything. And then a couple hours later it would start fine, but run like crap. meaning it would stutter and bog down, lose boost. So im hoping them replacing the charge piping will solve my issue, because it is pissing me off beyond belief, haha
good luck
Dropped car off this morn. I sure hope they find it. I think their tech support is telling them to go the direction of the sensors. I found out the reason they swapped places with the sensors was to see if it would cause a code. FAIL. I personally think it is in the direction of the BPV, but what do I know.
I think if they would contact the engeneers who created this "tune" they may get some answers since it seems to be a GM1 problem. well I guess another week without my car. yipeeee.
I need to find how to find out what day my car was built. Someone must have been pissed off or hung over!!!! prob a monday. Still hung over and pissed that they had to go to work!!
Will keep you updated
I have been to the dealer with the turbo flutter and 5psi boost too. All they tried to do is swap positions of the MAP sesor with the boost sensor. Like thats a fix. well it did not work. It was doing it today but after 40 miles of driving it pulled itself out of it. If i had a hole in the charge pipe wouldnt it flutter and be in limp mode all the time and not so randome? Also could this be the case since my car is so new and only has 13k on it.This problem is driving me crazy. when you say some days it starts and some days it wont start ,do you mean actually start or "act up"?sorry if that was a stupid question....
The start/no start is odd though, no matter how many leaks or powertrain issues I've had the car never refused to start.
It has happened after I got my forge BPV installed as well, so it did not fix it.
Not a big problem, but it's annoying when it happens! I just hope there is no civic ricer that wants to race me when it does, as I couldn't humiliate him him!!!
Exact same thing has happened to me several times...Maybe 5-7 times in the least 15 months or so. I've had GMS1 for a year and had it HP Tuned this spring, and it has happened maybe 2-3 times this year so far. Brought it to the dealer once but as it's intermitent they cold not find it. Most of the time it does this, flutters, boost @ 5 PSI and next time I take the car all is fine. It rarely happens, but still is annoying. The other day I drove it for a while and all of a sudden it "fixed" itself and was a lot better. I have about 90 000 KM's on the car, been stock for about 35000 kms, Stage 1 40000 and tuned for 15 maybe.
Just for the record I'm having the same problem. I have Stage 1 and a K&N Typhoon. Sometimes is works great, sometimes it flutters and limps @5psi. I haven't been able to get it to the dealer for weeks, so I don't know what they will say yet. I just went out and rotated the filter to 12:30 to see if it does anything, but I expect it won't.
Well i called the dealer and I guess the reason they switched spotts with the 2 sensors is because only one of the spots will throw a code. so they said that the sensor that went into that spot threw a code. So they replaced the 2 sensors. Boost and Map. Now they say they have boost in all the gears but something is wrong in 1st. If I am not mistaking, there was never much in first. could it be they think there was more in first that really is? My car has been there since Sat. they still have not even looked at the "creaky clutch pedal" yet.
