maf tuning
When i disconect the evap my stft go to -30 at idle is this normal ? Im trying to tune my fuel trims...
Doesnt sound normal to me. No codes?
Not normal at all.
Disconnecting the evap plug under the hood should disable the LTFT, unless you've moved your maf to the lower charge pipe without tweaking the maf tables significantly. Also do a boost leak test with the plastic line going to the evap solenoid unplugged (one that runs back to the gas tank) and see if the solenoid has failed. I've had mine fail that way before. |
kk im gonna try again and see what happens . I think i forgot to reset my fuel trims last time before i started ...
When you disconnect the evap solenoid it zeros the ltft and then you only have stft
kk everything is good i tested it by just tuning my idle and the stfts went from -20 to - 3.1 with a few paste by % . Its raining to much to get a driving log atm . Ill have this thing dialed in tomorrow .
thanks guys |
Well things are going good for my fuel trims but im getting 14-16 degrees advance at wot and my spark tables are set to 12 degrees , why is the timing higher then what i have set in the tables ?
think i figured it out i set the base correction tables to 0 in the areas it was adding timing
