misfires
My rev limit is stock. Had my tuner leave that alone to save the motor. And yes I have pegged it before an it does pop both then and yes when I nls. It's not the popping I'm worried about. It's an actual miss in the motor. I use my nls, and then hit the next gear, and its like an injector or coil or plug cuts out until I let up.
I found this would happen if I tried to use Launch Control and NLS when the car wasn't fully warmed up. Made this same miss after shifting (felt horrible). Needless to say I've learned my lesson after a couple attempts. I always make sure my engine is good and warmed up before trying anything like that and it hasn't happened since.
Keep in mind any cars engine takes a while to fully warm up. A friend of mine who recently went to school for is apprenticeship said you would be surprised how long it takes for the pistons to expand and all that other junk that happens when a car warms up.
Also the stock redline is 6250 rpm.
Looks like you have some warranty questions, TY8495. Send me the last 8 digits of your VIN and mileage and I can get you specifics on what's covered on your car right now.
Sarah, GM Customer Service
damn, injector seals, didnt think of that one as well. I thought those only went out on e85 cars?
anyways, mosy likely the misfires are from the gapping in the spark plugs or a fueling issue....gl
61,407 on the miles.
All I really need to know is what is covered under warranty. Like my other posts say, I have a few small issues w the car. When I let out of wide open throttle, it smokes, mostly white but has some blue in it. And it smells like oil, and it pours out bad. I've been told that could be a couple things. I think it's valve seals.
And secondly, the "misfiring" issue, maybe that's the fuel pump?(mechanical high pressure can driven).
And lastly, is the clutch covered under warranty or would that be classified as just ware and tear and I'd have to pay for that.
Thank you, again!
Last edited by TY8425; 02-06-2013 at 10:44 PM. Reason: Forgot to put the mileage in.
Now mine is started to do it even when oil is up to temp (I assume is up to temp after 10 mins of driving); floor it in second, hit full boost and it does the machine gun around 5k rpms.
I'm thinking a sensor may be loose after dealership replaced piston ring, head and turbo.... maybe the crank position sensor is the culprit....does anybody have a diagram that shows sensor location?
My shift light thread is basically the same thing. Maybe try not using NLS since its pretty hard on **** unless you know you got an actually close line up. I just get that bad misfire when I'm going through gears and just barely touch rev limit due to tire spin then CEL flashes then I let off for a second since it sounds like it drops a cylinder then get back on it and everything is 100% . Thus my CEL is always on throwing 1,2,3,4 and engine misfire codes. Never throws codes it just picks them up if I rev limit on accident hence rev limit causes misfires.
I always thought it was my trifecta tune some kind of safety limp mode deal
I will soon be HPtuned let you know if it makes a difference and I ordered a raptor shift light
#36
When this happens, have you let your engine warm up properly?
#39
well... yeah... but moreso turbo cars. when you let go of the gas, and get back on it fast. it'll do it sometimes. my buddies evo did the same thing. and he told me all turbo cars are like this...
funny once he told me that, my car stopped doing it lol
#40
misfire: To fail to ignite when expected
detonation: rapid combustion in an internal combustion engine that results in knocking
Not all turbo cars detonate...poorly running turbo cars detonate
#41
I truly believe this is a sensor problem.
How many miles are on your car?
#42
MINE IS DOING IT AT 51K MILES. bUT LIKE I SAID, I HAD THE CAR SCANNED, AND MINE CAME UP AS A HIGH PRESSURE FUEL PUMP ISSUE, AND POSSIBLE FUEL RAIL AND MINE WENT INTO REDUCED POWER MODE.
#43
Another theory I would wonder about ..... with the way these cars can gum up the intake valves .... that it could be causing misfire issues as well as NLS issues . Direct Injection does have a few drawbacks unfortunately .
#44
I've seen misfires on my dashhawk when the car is in cat warmup mode but as soon as it idles down there gone . I know when mine sputtered after a NLS that it wasnt temp related cause the car had been driven for awhile before hand . It seemed to me like the system that keeps the boost pressure up during the shift does it with valve timing ....and either I was a hair off or the NLS system was .
Are the two solenoids the only pieces that interact with the cams? What else should I check?
#45
Thank you Sarah!
97121943
Thank you, again!
97121943
Thank you, again!
I included a section below from the 2009 Chevrolet Warranty manual that describes what is covered and what is not covered under this warranty (clutch linings are considered wear and tear/maintenance).
I hope it's helpful to you - let me know if you have further questions!
Engine Coverage includes: All internally lubricated parts, the entire pressurized fuel system (in-tank fuel pump, pressure lines, fuel rail(s), regulator, injectors and return line). Also included are all actuators and electrical components internal to the engine (i.e.: Active Fuel Management Valve Lifter Oil Manifold, etc.) as well as the Engine/Powertrain Control Module, module programming, cylinder head, block, timing gears, timing chain, timing cover, oil pump/oil pump housing, OHC carriers, valve covers, oil pan, seals, gaskets, manifolds, flywheel, water pump, harmonic balancer, engine mount, starter motor, turbocharger and supercharger. Timing belts are covered until the first scheduled maintenance interval.
Exclusions: Excluded from the powertrain coverage are sensors, wiring, connectors, engine radiator, coolant hoses, fans, coolant and heater core. Coverage on the engine cooling system begins at the inlet to the water pump and ends with the thermostat housing and/or outlet that attaches to the return hose. Also excluded are engine oil cooling hoses lines and radiators.
Transmission/Transaxle Coverage includes: All internally lubricated parts, case, torque converter, mounts, seals and gaskets as well as any electrical components internal to the transmission/transaxle. Also covered are any actuators directly connected to the transmission (slave cylinder, etc.) as well as any. Transmission Control Module and/or module programming.
Exclusions: Excluded from the powertrain coverage are transmission cooling lines, hoses, radiator, sensors, wiring and electrical connectors.
Transfer Case Coverage includes: All internally lubricated parts, case, mounts, seals and gaskets as well as any electrical components internal to the transfer case. Also covered are any actuators directly connected to the transfer case as well as encoder motor, transfer case control modules and/or module programming.
Exclusions: Excluded from the powertrain coverage are transfer case cooling lines, hoses, radiator, sensors, wiring and electrical connectors.
Drive Systems Coverage includes: All internally lubricated parts, final drive housings, axle shafts and bearings, constant velocity joints, propeller shafts, universal joints, wheel bearings, front and rear hub bearings, locking hubs, mounts, supports, seals, gaskets as well as any electrical components internal to the drive axle. Also covered are any actuators directly connected to the drive axle (i.e.: front differential actuator, etc.) as
well as any drive system control module and/or module programming.
Exclusions: Excluded from the powertrain coverage are drive system cooling, lines, hoses, radiator, sensors, wiring and electrical connectors related to drive systems.
#46
Thanks Sarah, I really am speechless in not expecting to get all this info.
Are there any MINOR modifications that will void the power train warranty?
