n00b question: how do I read the dipstick?
I cant seem to figure out how to read the dipstick on this car... :lol:
Most cars' dipsticks are marked clearly where max and mins levels are.... On the SS/TC.. it goes like.. top of the stick with handle <=== |xxx| | | |xxx| where's the max? the "|" at the top of the 3 smooth areas? or at the top of the "xxx" area? Thanks... |
it's much easier to just drain your oil and measure it with your measuring cups. should take 6 liters. haha no no but seriously i'm pretty sure it should be near or on the line but i'd say the x's are a good buffer zone. i've heard people say oil doesn't even show up on the dipstick until you add the 6th litre.
Originally Posted by Cobalt_Daddy
(Post 4466176)
wait.. i put in roughly 5 quarts for the car.. no idea how many liters... |
Originally Posted by JT-KGY
(Post 4466183)
yes.. usually the amount of oil to go from min to max is roughly a quart (for most cars)...
Originally Posted by Permafried-
(Post 4466372)
5 quarts = 4.78 Litres :)
The owners manual says 5 quarts, does it not? That's how much I put in, and my oil goes up into the top xxxx section.
I think that's where you want it, somewhere in that top xxx zone. |
Originally Posted by Koz
(Post 4468806)
(Post 4465983)
Most cars' dipsticks are marked clearly where max and mins levels are.... On the SS/TC.. it goes like.. top of the stick with handle <=== |xxx| | | |xxx| where's the max? the "|" at the top of the 3 smooth areas? or at the top of the "xxx" area? Thanks... if oil is in crosshatch zone (upper portion) = "FULL" or OK if oil is in lower crosshatch then you are low and need to add about 1 qt. We put in the "area" rather than a line due to complaints that reading was not "exact" so we gave "ADD" and "FULL" zones to account for some of the variation.... |
Originally Posted by More_Torque_More_HP
(Post 4473362)
Here is the quote from the design engineer:
if oil is in crosshatch zone (upper portion) = "FULL" or OK if oil is in lower crosshatch then you are low and need to add about 1 qt. We put in the "area" rather than a line due to complaints that reading was not "exact" so we gave "ADD" and "FULL" zones to account for some of the variation.... THANK YOU!!!!! I just wish that the user's manual explained it as well as you did... |
I just buy the 5.218 quart container for about 19.99 to 29.99 depending on the deal.
