New 2010 SS owner. Easy questions
Old Feb 17, 2018 | 06:51 PM
Eduardo LSJ's Avatar
Hi again guys
Just a couple easy questions. I'm a new turbo owner from a 07 SSNA. My car has a couple of things done to it cosmetically by first original owner so I'm curious as to what's stock or not.
-when I open the door it says TURBOCHARGED on the lower part by the seat. I assume this is stock right?
-since the car was debadged, on the dash passenger side it says again TURBOCHARGED. On my 07 it said "SS". Is that normal?
-my car has lights under the door armrests illuminating the door pockets. That normal?
-there's no center armrest in this car. The 07 SSNA had that.
-the parking/ebrake is MOMO. Stock?
Thankfully everything mechanical is stock. Car was 145 000 km for $7700 Cdn after taxes from some kid who had it for 6 months but couldn't afford it.
Old Feb 17, 2018 | 08:38 PM
cobaltssdude420's Avatar
Originally Posted by Eduardo LSJ
Hi again guys
All of that is aftermarket upgrades lol. The ss above the glove box was stock
Old Feb 17, 2018 | 09:29 PM
63 Nova SS's Avatar
None of that is factory. A lot of guys added the center armrest, which they robbed from other ssna cars or there was a lot sold to add it, like I added.
Old Feb 17, 2018 | 11:59 PM
The TURBOCHARGED silver badge is the stock one i see on the trunks of SS turbos. I guess the owner changed out the SS for the TURBOCHARGED from his trunk
Old Feb 18, 2018 | 12:03 AM
This is on the door frame. Is this stock? Its laser cut so i asummed yes right?
Old Feb 18, 2018 | 12:06 AM
I just said it's not stock as well as nova. Im pretty sure I know who makes/made those.
Old Feb 18, 2018 | 12:08 AM
i wasn't susure if you knew what ment.
after driving the SSNA for 3 plus years I miss the arm rest. But turns out I need both hands to control the torque steer 😂😂😂
Old Feb 18, 2018 | 12:14 AM
Did you buy that from a guy named jordan?
Old Feb 18, 2018 | 01:09 AM
Without flash interior
With flash interior
No flash door frame lights
Flash doorframe lights
Old Feb 18, 2018 | 07:19 AM
Dutchman's Avatar
Welcome fellow Canuck
Old Feb 18, 2018 | 07:25 AM
63 Nova SS's Avatar
There were a couple of companies who made the kick plates in your door jamb with different options of names that you could swap in. Don't know if any are still in business.
You can add the center console, it's not hard to do.
If you have torque steer first thing I would check is your rear control arm bushings. I have very little to no torque steer and I'm at 370whp. Stock cabs are prone to tearing. Rotated trans mount helps to.
Old Feb 18, 2018 | 03:14 PM
No it drives fine. I just wrote that because its a common thing I read on here; the torque steer. This car sounds and drives great. I found the original owner and sent him a msg on facebook. Lets see if he replies
Old Feb 18, 2018 | 06:50 PM
63 Nova SS's Avatar
Torque steer unless you are at real high levels shouldn't be an issue. The issue is everyone cheaps out and puts inexpensive parts on their car, and then complains about how poorly the car drives.
Old Feb 18, 2018 | 08:49 PM
Dutchman's Avatar
^This. You gotta pay to play. Good parts aren't cheap, unless you can find someone parting out what you need. Seeing as you are in Ontario you may want to look up John Powell he makes some great us stuff for our cars. I have a hardcore bar, air oil separator, control arm bushings from Powell
Old Feb 19, 2018 | 06:07 AM
63 Nova SS's Avatar
^rear cabs, rotated mounts,yyz springs, oil separator, harness bar, and soon -under car rails, all from Powell. Good stuff.
SStevie
Mar 22, 2015 01:46 PM
buckshot3448
Feb 4, 2010 12:47 PM
Billig ss/sc
Oct 29, 2009 02:27 AM
John
Sep 5, 2006 01:21 AM
