NLS'ing at the track
I have a question for all the people that have done NLS successfully. I am going to a 1/4 mile drag strip tomorrow night for the first time and I'm trying to decide if I should try to NLS or not. I've tried Launch Control a few times and I didn't like it. I've also done a couple 1/8 mile drags before and I haven't used NLS, but since I will actually be getting timed at the 1/4 mile strip I am debating on trying to NLS. To be honest i'm also a little bit nervous to NLS and F**K something up in general. Any tips, pointers, or horror stories on this? Thanks guys!
ive heard horror stories. can't think of any right now, but i will say this. i used to NLS quite often and i can hit it every time. but after i read some of the stuff that was happening to peoples cars, i quit doing it period. track or street, i don't do it at all.
No Lift Shift feature requires the car to be in competition mode to properly execute. There is relatively little danger of screwing something up. The computer essentially controls the combustion process during a no lift shift. Pretty safe practice and many many real drag/street/track racers use aftermarket wot/nls boxes to accomplish this very same feature. Its a pretty good advantage after you reprogram your brain. Do some research and youll understand the specifics a bit more.
POWERshifting is what a lot.. and I mean A LOT of people mistake for No Lift Shift. During a powershift, there is no computer controlled process, the engine keeps going as it normally does, RPMS go up and then BAM. get slammed into the next gear. This is equivalent to setting 100 years worth of Hun militants to beat the crap out of your transmission and drivetrain. Some drag racers use this practice, mostly those who dont know better, or those who do and can afford a new transmission on the fly.
What gets me is the fact that my brain is already programmed to let off the gas when I clutch and shift...so changing that up is out of the ordinary. I have tried to go over and over in my head to NOT take my foot off the gas depress/shift/let off clutch and it just seems that I get a sick feeling that I will mess something up. I'm probably just being a puss, but I'd rather not break something just to get a miniscule time difference.
The older we get, the more stuck in bad driving habits we get. So the earlier you learn new skills, the easier it will be. Ive caught myself more than a few times using improper techniques and/or at the wrong times.
Much like any new skill, it will take practice and time to learn. If it is not worth it to you due to some irrational fear, then i would implore you to do your research about the no-lift-shift technology. It has been implimented in performance racing for years. When you learn a new skill, you will make a mistake or two. Nobody is born knowing how to do this, every single one of us starts at level 0. The more you understand the technology and how it works, the easier it will be to train your brain. It is just another tool you can utilize. It is not mandatory, you will get to the end of the track one way or another, its just another method. It IS a very good sign that you arent so egotistical as to say "no point in no-lift-shift, that features garbage" like most people. It will be 100x harder to learn new skills if you start thinking you know everything.
All anyone needs to do is go try it, It works in any mode exactly the same. It holds the rpms while you make the shift, you have a 1 sec window to do it. Anyone can go try and see the truth!
You can do it in either mode. People that have a hard time getting this feature to work are simply not doing it right, it has nothing to do with what mode the car is in. There has been other reps etc speak on this feature as well and have made the comment that given the consequences of forgetting to press the comp button, it was decided to enable it full time. Ive done it in both modes, both modes resulted in a butter smooth NLS and a nice pop ...
all those horror stories are just people who cannot do it correctly. they shift too slow, or at the wrong rpm, or who knows what else. ive nls 1st all the way thru 5th on a dig and no problems. the 1-2 nls is hard, sure, but if u time it right, it wont **** anything up unless your getting wheel hop and other factors. ive only messed up a NLS about 2 or 3 times when i was getting used to it. now, its easy as cake. also, if the car breaks because of NLS, it will be covered under warranty. they cant deny your warranty for doing something that is advertised on the car. unless ur modded of course.
PS As its been stated, NLS can be performed in any mode. The only reason to turn Comp mode on is to engage Launch Control. The only reason why it may be safer to NLS in Traction off or Comp mode is because if your in regular mode and the car detects slip at wot and your about to NLS, bad things can happen.
im not here to be a target for you buddy. What I should have said is "SHOULD be in comp mode to properly execute". I am not a guru and the last thing I want to do is spread misinformation, but I do have experience and tons of it. Ive reached a point where id like to try to share some of that experience with others in order to solidify my techniques, and be challenged.
Thanks for all the tips guys...trying it on the street first would be much smarter for first-timers like myself due to the fact that everytime I've been to a track so far I get more nervous than when I'm driving around town. When that adrenaline gets pumping it's much easier to slip up! Plus everytime I lauch, I either launch too low and bog or too high and can't get ANY traction til I hit 3rd...
Who's had great results with their launches and at what RPM are you launching?
I lowered my tire pressure to 28 up front the last time I was at the track and it seemed ehhhh alright I guess. Maybe 2500 is the sweet spot b/c 2000 was too low and 3000 was too high, for me anyway...
run 26psi
launch around 2200 to 2500
regular shift to 2nd, and NLS to 3rd and 4rth.
this you will like and with your sig I bet you get great times....
post them up afterewards,
Im guessing after you get it all figured out and your first time out, you get 13.3's maybe 4's
