oil sprayed everywhere
well engine runs fine holds boost no problem just noticed the check valve is broken so when it was stuck closed it built up pressure in the crankcase leaked out where the braided line meets the plastic (the part where the fuel line tool is needed to remove it )
correction it was broke inside where it connects to braided line so air and oil was leaking out under boost . but ya I actually was very worried for a min first thing I checked was oil dipstick tube and bottom of oil cap to see if it was blow by they were dry thank god
