Part number for RPD?
Old 09-16-2008, 04:23 PM
Ferretts's Avatar
Does anyone know the part number for the reconfigurable performance display that comes in the 09 tc?
Also is there a ballpark price, and what do you connect it to?
Old 09-16-2008, 04:57 PM
krispy's Avatar
pretty sure its this:
25784528
list price: 335.28
There is a specific dashboard wiring harness that costs $371 (25947708)
To connect otherwise you need in ports:
A. HS GMLAN (+) 2500
B. HS GMLAN (-) 2501
C. Illum. 339 [from BCM port J4-F6]
D. Batt 1440 [from BCM port J4-C1]
E. HS GMLAN (+) 2500 [to BCM port J2-2]
F. HS GMLAN (-) 2501 [to BCM port J2-20]
G. empty
H. ground 651 [IP ground]
Might be able to get it to work if you route off of the ports going into the BCM (splice into or route around)
Not sure what is the mating connector though. Not sure how to find out what that is, but once you find it you need to get the mating connector and the terminals that fit into it, then wire it all up. I will say good luck to anyone doing this, I'm not going to bother since I don't feel comfortable splicing into GMLAN wires.
Old 09-16-2008, 05:20 PM
1WhiteSSTC's Avatar
25784528
list price: 335.28
G. empty
well that sucks, $300 for a fuking wiring harness
Old 09-16-2008, 05:21 PM
mkulrey13's Avatar
Not like its mass-produced...
Old 09-16-2008, 05:29 PM
Tomtwtwtw's Avatar
This harness is to plug it into the '08 models, or needed for the '09s?
Old 09-16-2008, 07:20 PM
krispy's Avatar
Its the harness for the whole dash, the non-UAF harness is 25947709 for 09 and is $369. There is no jumper harness.
Old 09-16-2008, 07:22 PM
Jimmys2007CobaltSS/C's Avatar
noth worth it imo
Old 09-16-2008, 07:27 PM
Tomtwtwtw's Avatar
Ah, so in other words, still no hope of plug and play compatibility with the '08s?
Old 09-16-2008, 08:06 PM
krispy's Avatar
Found connector info:
Connector Part Information
* OEM: 15332145
* Service: 15306407
* Description: 8-Way F GT 150 Series (BK)
Terminal Part Information
* Terminal/Tray: 12191812/19
* Core/Insulation Crimp: E/C
* Release Tool/Test Probe: 15315247/J-35616-2A (GY)
Old 09-16-2008, 08:30 PM
BowTieTillIdie's Avatar
So if you have the wiring diagram you could make it work with 3m quick connectors ? just not into paying for a 400$ wiring kit lol
Old 09-16-2008, 08:32 PM
pimpnwink's Avatar
damn and i was hoping it would work in my 06
Old 09-16-2008, 10:00 PM
40rty's Avatar
WTF! So I can install this thing in my 08? Where can I order? Dealerships? Who?
Old 09-16-2008, 10:08 PM
1WhiteSSTC's Avatar
Overall its looking like an extra almost $1000 to get the harness, RPD unit, and then have it installed at the dealership too.............seems a little much
Old 09-16-2008, 10:12 PM
40rty's Avatar
I'd do it, **** it!
Old 09-16-2008, 11:08 PM
If someone gets me the wiring diagram I will buy one make my own harness and give you guys the info step by step
No one has the diagram? I just need the pin out.
That would make it 400 bucks and some wire
Old 09-17-2008, 11:25 AM
krispy's Avatar
Alright guys, here is all the wiring to do it, all the wires already exist in the 08 model from what I see. It looks like for the power/ign you want to run in parallel to the existing wires. For the Data it seems like they splice into the connection (series connection). The ground is just a ground.
If you find the right dealership that gives you a deal on parts the RPD [P/N: 25784528] should only be $200. (Thats right around employee price)
Source for RPD connector 15332145 ($1.90 + shipping for 1)
http://www.mouser.com/Search/Product...ELsIvbRg%3d%3d
Source for terminals for connector 12191812 ($0.11 each for 25)
http://www.mouser.com/Search/Product...inqRkkgA%3d%3d
The following 3 users liked this post by krispy:
firehawk618 (11-10-2015), silverback (10-16-2016), Ugoogalee (02-20-2018)
Old 09-17-2008, 02:44 PM
40rty's Avatar
This thread is ******* awesome and interesting.
Old 09-17-2008, 04:04 PM
Cobaltss/TC's Avatar
Watch after you install yourself GM comes out with a piggyback connector and the display for 500 bucks, lol i can see this happening.
Old 09-17-2008, 04:08 PM
Tomtwtwtw's Avatar
I'm looking forward to the first thread with some pics / videos of one of these retrofitted to an '08.
Old 09-17-2008, 05:12 PM
krispy's Avatar
Alright, I did some more thinking:
15317575 is the female DLC (OBD2) connector
12110256 is listed as the mating male DLC connector, but thats a huge beast that I can't find
12110252 is another male DLC OBD2 connector and I'm not sure why that isn't listed as a mate to the 7575, I thought all OBD2s were standard. It is listed as a mate to another delphi female DLC (which listed both 252 and 256 as connectors that work)
These can all be found @ http://connectors.delphi.com since they are all delphi connectors.
My thought is: a male DLC connector with 2 wires coming out of the GMLAN (+) and 2 out of the GMLAN (-) plugged into the correct spots on the RPD connector. Then a cigarette lighter power source should supply the other 3 wires (power/switch/ground) for the RPD. Thats 7 out of 7 required there, no splicing of wires required. I'm not sure if it would actually work, it really depends on how the GMLAN interfaces w/ the RPD.
Old 09-17-2008, 05:15 PM
1WhiteSSTC's Avatar
lol someone sure has some type of engineering degree
Old 09-18-2008, 01:22 PM
Yeah I am working on it already I have ordered the RPD so you guys will see if I fry it or successful completion LOL
Wish me luck
Old 09-18-2008, 02:25 PM
krispy's Avatar
well you have all the wiring diagrams that I could find involving the RPD + connector information
good luck
Old 09-18-2008, 02:33 PM
good luck
I have been reading these types of diagrams for a very long time & it just take some critical thinking and if I can find the molex connectors or buy molex connectors my self from gm or another retrofit source ...I could make the connectors my self and sell them for 200 Ofcourse Ill make anyone a connector- for cost of shipping & materials if they help would think it would be around 60$ for a home made version but i'll give you the plans too .. Come on dudes work on this so we don't have to spend 400 bones on the crap.
Old 09-18-2008, 03:40 PM
krispy's Avatar
Depends on how people want to do it. If it works, with the DLC + cigarette lighter way there is no way the wiring would cost $200.
But if you also noticed I included a link to mouser.com which sells Delphi connectors and all the connectors are Delphi, not molex
BTW, how much did you pay for the RPD?
Quick Reply: Part number for RPD?
