Piston3's LDK Swap
#228
Ahhhhhhhh gotcha. Like others have said...canned tunes can be *****. Even from awesome companies like zzp. I feel like once your hptuned all your problems will be solved. I have never seen knock at 23.5 psi putting 310 to the wheels on 91.
#230
You'll get slight knock being on the LDK on a dyno though. Matt from ZZP didn't understand why, but on the street he didn't get any knock. I had mine dyno tuned by zzp originally but now its tuned by James.
#232
I get phantom knock every once and while. Found out on a recent log to figure it out it seems to be cylinder 3 for me, only full load and only 3 degrees. Goes from 0 to 3 so its phantom. Just need to spend more time chasing down the cause of the phantom knock on mine. I would assume a canned tune would be a safe distance from causing knock
#233
That's what I thought as well. Canned tunes are conservative, so I didn't expect any knock. So it might not even be real? Also I've noticed this only happens when it's warmer out and intake temps above 80-85 degrees and gets worse if I get heat soaked in traffic.
#234
Thought I'd share this decent cell phone pic that isn't a picture of catastrophic damage. Let's hope all goes well Tuesday! She'll be in capable hands.
#235
I've checked each change he's made in the tune... he hasn't turned anything off related to that. The way he logs knock readings is different then most but I've used my own configuration and ZZP's and the knock readings are good.
#236
Any guesses on final numbers? Will be 91 octane and tuned by PWerks. 2000 miles on the LDK crate motor, stock turbo, k&n, ZZP ic kit, catless DP, GMPP clutch, 3 bar maps.
#241
#244
I don't have an answer for that. My brother did a large majority of the work though. I don't recall us having any issues with those or having to cut them. Someone put some kind of sealant on yours?
#246
Happens all the time. I'm usually afraid of breaking things so I often am not aggressive enough. One time I ruined a $3000 dash panel in a Lexus SC while replacing the radio and being a bit rough with it. I stripped an oil pan once too and my boss bought me a super short 17mm lol. I'm pretty careful these days.
#248
Can you ask your brother the easiest way to remove the hydraulic clutch system fitting on the top of the trans close to the front of the engine bay? That is about the only thing I have remaining along with the shifter cable end links. I wish i had a pic of it. Its basically right under the fuse box runs up to the steering column, It has to be the transmission fitting thats the only thing i can think of.
Does anyone know if its the same way the SS/SC book says to remove it?
Also the tie rods on these things are the dumbest thing ever. that 17mm inside bolt strips immediately I had to use vice grips to get it to keep from spinning.
#250
You pull off the clip and pull it out. Cap the line with a rubber cap so you don't loose a bunch of fluid. And to get the block off you pull the other clip and lift it. It's not hard. they are really basic things.
The tie rods should be 18mm unless your talking about the little square drive on top. An impact brakes those bolts loose really easy.
