Piston3's LDK Swap
Old 04-23-2014, 08:59 PM
  #201
Piston3's Avatar
Yeah I'm more interested now in other areas of the car. Like upgrading the little stereo that almost could but didn't and fell on its face.
Thank you for your input everyone. Booking a dyno tune very soon. Then it's time for spinning chrome wheels and a shopping cart wing.
Old 04-24-2014, 09:20 AM
  #202
crashher0's Avatar
Originally Posted by Piston3
This. Get one and curse less.
Attachment 5088
Meant to ask a while ago, What exactly is that?
Old 04-24-2014, 01:17 PM
  #203
Piston3's Avatar
It's a snap on tool for putting on and taking off hose clamps. Makes taking lines off the turbo, and everything else a joke. Reaches right back there. Just position and squeeze.
Old 04-24-2014, 10:32 PM
  #204
nutty21's Avatar
Engine went in my car, got an LDK on the way with ZFR.
Valve dropped in cylinder four.
Took it to the dealer twice for miss fires and they told me nothing was wrong keep driving it.
Then engine gone...
GM won't do crap about it. 84000km on it...
Way to stand by your product and service...
Old 04-24-2014, 11:53 PM
  #205
Piston3's Avatar
Then engine gone...
They are unhelpful and their techs know **** about these cars. The oil change boy put my sleeves in. 24 hours on a 12.5 hour job over 3 weeks...You're much better off now.
Oh also the tech line guys said 26 psi is normal for GMS1.
Old 04-25-2014, 10:49 PM
  #206
Piston3's Avatar
So I was seeing up to 6 degrees of knock retard today in traffic at part throttle with light boost. Had some heat soak and intake temps were around 110-116. Is this normal? The only thing I've changed is going from 91 octane to 93 octane fuel from a different station so I'm completely confused. It was bucking a bit too and not from driver mod...
WOT was normal at 1-3 degrees of KR and it all seemed to clear up after hitting the interstate and cooling off to 85 degree intake temps.
Just a bit concerned since it's not even summer yet. Hopefully this can all be addressed when I get tuned.
Old 04-25-2014, 11:19 PM
  #207
cfsnipers's Avatar
Ma and Pa gas station or a proper gas station like Shell?
Old 04-25-2014, 11:26 PM
  #208
Piston3's Avatar
I stopped at Murphy USA it's in front of a Wal-Mart and half the time the pumps are full.
Old 04-26-2014, 12:03 AM
  #209
cfsnipers's Avatar
Could be bad gas bro. I don't know. Never seen that kind of knock retard in my car ever. No matter how hot it got.
Old 04-26-2014, 12:13 AM
  #210
Piston3's Avatar
Could it be the extra bit of compression from the LDK? Otherwise I'm blaming the gas.
Old 04-29-2014, 11:37 PM
  #211
Piston3's Avatar
Will be tuned in two weeks.
Old 05-01-2014, 01:12 PM
  #212
nutty21's Avatar
HELP!!!
So got this email from my mechanic:
The map sensors between your old engine and your new engine are not the same, the electrical connector from your engine harness will not plug into the new sensor supplied with the engine and the old sensor from your old engine will not fit into the new manifold as the sensor is too big for the hole. Wondering if you have an electrical connector or do we have to swap the whole manifold over?
Anyone else run into this???
Old 05-01-2014, 01:33 PM
  #213
crashher0's Avatar
HELP!!!
I may be wrong but I think piston3 just swapped over manifolds, I heard it was the wrong size and the bolt to hold it down wasn't centered on the hole. I planned to just swap over my LNF manifold. also its painted and I want to reuse it.
Old 05-01-2014, 02:28 PM
  #214
Piston3's Avatar
Yes. We swapped the LNF manifold onto my LDK. Works just fine.
Old 05-01-2014, 05:25 PM
  #215
nutty21's Avatar
ZPP say:
You can run your sensor in the new manifold if you change the o-ring and remove the steel sleeve.
Old 05-01-2014, 08:13 PM
  #216
crashher0's Avatar
ZPP say:
Or you can just swap over the intake manifold which is super simple to do, especially with the engine out. More of a difficult if you have to do it in the car like I did to paint it.
Just saying the intake mani is one of the simplest things to remove and swap.
Old 05-01-2014, 10:24 PM
  #217
Piston3's Avatar
Took all of two minutes including swapping the new throttle body on.
Old 05-03-2014, 02:30 AM
  #218
Piston3's Avatar
Ok so this is odd I guess? Have about 1500 miles on the new engine now and it seems to have picked up a bit. Screeching the tires quite a bit through 2nd if I'm on it.
I've heard of new motors not making their peak potential until 1500-2000 miles. Fact or fiction?
Also...10 days until dyno tune.
Old 05-03-2014, 11:17 AM
  #219
cfsnipers's Avatar
100% fact. Things are still seating. Might not see full power til 2500 miles.
Old 05-03-2014, 09:17 PM
  #220
ctn2mb's Avatar
I'll tell you my LDK has 0 knock....... and I have the LDK manifold with GMS1 sensors.
Old 05-03-2014, 10:38 PM
  #221
Piston3's Avatar
Light throttle knock was back tonight. 1-2 degrees. Along with "no data available" on the RPD for A/F ratio. Pulled into a parking lot, shut it off, waited a minute, then drove away. It was working again by the time I got to the stoplight. Should I just get a sensor now? I can't be having an issue like this a week away from getting tuned.
Old 05-04-2014, 02:06 PM
  #222
ctn2mb's Avatar
that no data available your having is usually that top map sensor. I would buy the gms1 sensors.
Old 05-04-2014, 04:08 PM
  #223
cfsnipers's Avatar
You'll definitely want the 3 bar map sensors before u get tuned. You can't install them until you are in the dyno shop ready to go though.
Old 05-04-2014, 05:53 PM
  #224
Omiotek's Avatar
you can if you have a really short drive.... passed that i wouldnt do it.... the plug and play connectors kind of suck too so i dont recommend them.
Old 05-04-2014, 06:08 PM
  #225
Piston3's Avatar
I already have 3 bar maps from the GMS1. All other data was reading fine. Just no A/F at the time. No problems cruising around today and no knock. I know I was in a bind during install and had to use a brown AC seal on my top map sensor but it was an exact match to the one that ripped coming off. Also my sensors are not plug n play and the wiring looks to be solid work.
Quick Reply: Piston3's LDK Swap
