Pointers on injector seal installation
I bought the Kent Moore installation tool and black seals. Is it pretty straightforward? Put the taper on the injector, seal on taper, then mash down with the large piece?
Insight from the experienced appreciated! |
You pootieheads wasted my life! Stared for thirty minutes, destroyed a few seals, but eventually figured it out..... I know at least one of you used the tool, ya could of posted playa!
Instructions: Slide taper over injector, push seal down a bit on the taper until diameter the same as skinny part of tool, use skinny part of tool to push onto injector seal groove, then use fat part to shape the seal. |
Been posted before. Many times. Glad you figured it out.
Easier to just buy the whole rail from monograt. :)
