Questions regarding GM Stage-1 kit on Cobalt verses HHR......
Now, if this topic has already been covered, or beaten to death in the past, please accept my apologies.
Ok, I just noticed that the Stage-1 kit shows higher HP and max torque for the HHR and Solstice Sky.
What is the reason for the lower figures for our cars?
This is what I found. Please see below:
Cobalt 2008-2010 HP & Torque ratings:
280HP @ 4,700 RPM
320 lb,-ft of torque @ 4,300 RPM
Kit disables "learn down feature"
This performance upgrade maintains no-lift shift feature on Cobalts and HHR's and adds it for the Solstice/Sky.
Note:
Solstice SKY HP & Torque ratings:
290HP @ 5,200 RPM
MT 340 lb,-ft of torque @ 3,600 RPM
AT 325 lb,-ft of torque @ 3,600 RPM
HHR HP & Torque ratings:
290HP @ 5,200 RPM
MT 315 lb,-ft of torque @ 4,800
AT 315 lb,-ft of torque @ 4,800
19212670 Performance Upgrade Kit for Cobalt, Solstice, GXP.SKY, HHR
Applicable: 2007, 2008, 2009 Solstice GXP/SKY RedLine, 2008, 2009 Cobalt 2008, 2009, 2010
Installation labor: not included. Guideline is 1.2 hr for the Solstice/Sky, 2.0 for the HHR & Cobalts.
Premium fuel is REQUIRED with this kit.
This performance upgrade enables no-lift shift feature on Solstice/Sky. NLS is already included on the HHR and Cobalt.
This kit needs to be installed by a dealer and reflashed by the dealer. It does not void any warranties.
What's in the box:
1 - Bolt Tmap Sensor
2 - Connector Sen-MAP w/ leads
1 - Sticker Premium Fuel
1 - Label Cert
2 - O-Ring T-MAP
2 - Sensor T-MAP
1 - GM Performance Decal
1 - Instruction Sheet
Ok, I;m done.....Old Veteran Car Dude
280HP @ 4,700 RPM
Note:
290HP @ 5,200 RPM
290HP @ 5,200 RPM
What's in the box:
1 - Label Cert
2 - O-Ring T-MAP
2 - Sensor T-MAP
Here is what GM HPVO's Bill Duncan had to say about the differences in the HP and TQ between the Cobalt and HHR SS.
The difference in HP between the HHR SS and the Cobalt SS stage kit is rooted in the airflow into the engine, the "suck" side of the turbo. The two air cleaners are of different designs and the engine has reacted differently to the added boost of the stage kit. The differences are this: the HHR SS air cleaner is mounted to the engine and rocks with the engine, where the Cobalt SS design is mounted on the inner fender and must allow the engine to rock independently. To allow these different mounting methods, the duct from the air cleaner to the turbo on the Cobalt SS has an added flexible section which causes a different air flow than the HHR SS and therefore different maximum horsepower numbers. On the plus side of things for the Stage 1 Cobalt SS, it makes 5 more lb.-ft of torque than the HHR SS and delivers more torque from 3400 RPM to 4700 RPM due to these differences in airflow as well.
NP 8) The HHR SS's stock air box is pretty cool IMHO. Dosen't your HHR come with a K&N type cone filter from the factory? I was looking at the K&N intake and they leave alot of the factory air intake in place except the Lid and the air box to turbo tube ....... GM must have put some thought into that airbox 8)
Later
Allex
I'm not sure how GM stage 1 reacts to an intake .... but i do remember when GM was talking about stage 2 for the Cobalt ....... All it was going to consist of was a GM air intake , so to me that says the stock intake is a restriction .
If the intake system lowers the restriction you will get increased horsepower & torque depending on how much the restriction is reduced and where in the flow curve the reduction occurs.
Turbo Johnny
Feb 21, 2019 09:41 AM
breds2k
19
Sep 21, 2015 10:24 AM
Josh@ottp
Sep 8, 2015 10:18 AM
