Random Cylinder missfire's
I have a 2008 cobalt ss tc and it has injen cai injen charge pipes mpx downpipe mpx catback exhaust. It is throwing a random misfire dtc. noticed the electrodes on my spark plugs are much lighter then they used to be. measured 65 psi before the fuel pressure regulator . did a compression test also. 165 psi across the board. Cleaned MAF sensor, noticed way high air fuel ratio's at higher rpm's but normal at idle, I believe idle should be at 14.75 to 15 but not positive. Any further suggestions to figuring out this problem would be great, thanks
how many k on the car, could be carbon buildup if its higher milage.
Flashing CEL or interceptor?
Originally Posted by Aleksey
(Post 6967851)
Try scanning it to see what cylinders and if there are any non-CEL illuminating codes?
(Post 6967861)
This is gonna sound absurd, but if you're on the factory battery, replace it. Get a good battery, Duralast Gold, etc. No joke, that stopped by misfiring and I know that's been the solution to a lot of people's misfire problems on here.
My random misfires on all cylinders was caused by spark blugs. They were black is shit so I wirebrushed them, re-installed them, CEL gone, and car ran like a champ. Even got me 30mpg afterwards. Shifts better, idles better, breathes better and saves me money at the pump. Eventually replaced the old ones with new ones after O'reily's had to special order mine.
Originally Posted by cruzcontrol
(Post 6969054)
just replaced them a couple weeks ago gapped them to .035 been doing alot of trouble shooting the past few days and it looks like its leading me to believe the MAP sensor is bad its around 33 kpa at 20 vacuum isnt it supposed to be in the 60's ? |
Not sure. I gapped mine originally at .035 too but at a cold start I'd get stumbling and after I'd get on the road it'd be fine. So I tried .032 and that solved everything.
Oh and my car has 32,000miles as well.
Originally Posted by Speed_Thrills
(Post 6968947)
Originally Posted by GAGNE
(Post 6969337)
I had misfire issue also. Regapped new plugs at .032 and problem went away
(Post 6969834)
Is that at idle? Warm idle? I'll check my interceptor when I go out to lunch today
(Post 6969838)
would a bad map sensor and or tmap sensor cause misfiring also my map sensor has incoming voltage of 5 but no outgoing voltage. that calls for a new map sensor right? opinions would be great thanks |
Have you checked your valves to see what condition they are in. I would take a peak and you will probably find them to be in pretty poor condition.
(Post 6972095)
was your misfire while making boost or at idle?
(Post 6972093)
yes that is at idle. and temp was about 100 degrees on car
(Post 6973793)
33 is definitely good.. That's what mine is
