RPD Problem
Old May 19, 2012 | 02:57 PM
Fastgti69's Avatar
RPD Problem
Never happened before. I was just going through it and it said Boost not avail.. What the hell do I have to do?
Old May 19, 2012 | 02:58 PM
MastaShaKe_88's Avatar
someone stole the Turbo out of your car.. praly the turbocharged badges 2, you should check
Old May 19, 2012 | 03:07 PM
SSlobalt's Avatar
TMAP sensor went bad (likely oil on it). Replace sensor and continue on.
Oh, and LOL at Masta!
Old May 19, 2012 | 08:32 PM
Fastgti69's Avatar
lol so what do i have to do? I'm not under warranty.. is it the sensor for the intake?
Old May 19, 2012 | 10:01 PM
RYRO14's Avatar
Are you Trifecta Tuned? MIne did the same thing but the reading would come back a couple minutes later.
Old May 20, 2012 | 02:24 AM
Fastgti69's Avatar
Yes, but I have been for almost a year now. This is the first time it happened... I will check again later tonight.
Old May 20, 2012 | 02:28 AM
Maven's Avatar
you should check for codes and do some diagnosis before you throw parts at it....
Old May 20, 2012 | 03:40 AM
Fastgti69's Avatar
I'll check it in the morning, I have a CEL but that's from the catless DP.
Old May 20, 2012 | 06:39 AM
SSlobalt's Avatar
MAP sensor in coldside pipe is the TMAP.
Looks like this guy has a similar issue, but different cause:
https://www.cobaltss.net/forums/08-1...oblems-279120/
Old May 25, 2012 | 11:06 PM
Fastgti69's Avatar
Okay so I pulled up some codes
P0036 Powertrain H025 Heater control circuit Bank 1 sensor 2
P0107 Powertrain Manifold absolute pressure/barometer pressure circuit low input. <<
I'm guessing it has to do with this one..
What does that mean lol..
Old May 26, 2012 | 12:01 AM
Maven's Avatar
p0107 basically means the MAP sensor is sensing zero pressure. check for broken or disconnected sensor, damaged wiring.
Old May 26, 2012 | 12:43 AM
Fastgti69's Avatar
Will do, and if everythign is okay I need a new map sensor. I was reading about some ****, would I need a 3bar map sensor since I'm tuned or how does this go?
Old May 26, 2012 | 01:04 AM
Maven's Avatar
If everything is okay you PROBABLY need a new sensor, you would need a new stock sensor. your tune doesnt matter unless ouve changed to GMS1 sensors, then youd need a new one of those. You wont be changing to a different styl sensor though.
Old May 26, 2012 | 05:20 AM
SSlobalt's Avatar
Looks like we're not just throwing parts at it, afterall. CED is your buddy.
Old May 26, 2012 | 12:34 PM
Fastgti69's Avatar
Thanks guys, so I would go to the dealer and tell them I need a new MAP sensor on the intake manifold and thats it?
I heard I can try to clean it cause maybe it got oil on it or something..
Jan 12, 2016 12:01 AM
dennis69
Oct 20, 2015 07:39 AM
Sep 27, 2015 08:53 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
