Shifter bushing stuck
So I bought some zzp shifter bushings and for the life of me can not remove the top drivers side one. anyone ever have this happen? is there some secret im not aware of to remove this? lol
I think this is exactly what I am experiencing. I have the original rubber bushings in there and I am trying to replace them. I have all 4 bolts off and the right side of my shifter housing comes up no problem, the left side feels like it's glued in place. I've gotten a pry bar in there with no luck; they just won't budge. Has anyone else had this issue and figured out how to get these things out???
Any thoughts on what could possibly be holding them? I sprayed some pb blaster in there and I've managed to get the washer insert to spin. So it's not seized to anything. What the hell could be holding this in??????????
After playing more with this it almost seems as if the rubber bushing bonded itself to the body of the car.
Just gotta say **** this and pry it out with a flat head screwdriver. Take a few breaks if needed, have a beer or so, say **** off at it a few times and just give it **** lol
This is how I started. I even managed to get a small pry bar in there and it won't budge. I think I may break the shifter housing if I keep at it. This is unbelievably stuck on there!
I'm trying to remember how it was I did it, its been like 3 years. I was able to get something to turn that rubber bushing, maybe it was a burr bit on a dremmel at a 90 degree angle from top side? It caught the rubber bushing and started it spinning, and I was cold and frustrated so I kept it going. The rubber started melting and I was then able to pop it right off.
Snail_SS (10-25-2017)
My bottom driver side was getting caught on the threading. First time I tried to install I end up doing only the passenger side.
My second attempt required me prying at it for a good 15minutes at different angles and then it finally popped out.
I used a screwdriver and a plastic fastener remover to do the prying. Bent the tip on the plastic fastener remover but was easily able to bend it back.
Was worth it. Great upgrade.
I ended up giving up for now. I might try and tackle this again later. I figured now was a good time since I was swapping the transmission and had everything already open. I had less luck with those bushings than the CAB bolts!
Go to any GM dealer & buy this. Spray some on it & let it sit for a few minutes. PB Blaster is useless. After using this stuff a few times you'll wonder how you ever got along without it. https://www.ebay.com/i/272888401069?chn=ps&dispItem=1
wouldn't for my situation. The reason why mine was stuck is that the inside of the metal part of the bushing wasn't 100% smooth. There was a little metal bump getting caught on the threads. I had to pry it the F out. Was afraid of damaging the threads, but the threads had zero damage.
