Shifting SUCKS in my car....
So just picked up a new to me 09 SS and after a few days of driving I have noticed a few things.
1. The transmission is a PAIN to get in reverse. Sometimes it goes right in and other times it acts as if there's an interlock preventing it. NO amount of going forward makes it go into reverse. It just goes in eventually with enough fiddling around. It's NOT the shifter adjustment. I have gone over it with a fine tooth comb and ruled it out. 2. It's got some really fancy looking short throw shifter. I hate it. It's far too stiff and vague for my liking. Perhaps the other issues I'm having are making me hate this shifter but I have nothing to compare it to. 3. This car absolutely, positively will NOT change gears at high RPMS without letting the rpm's drop a whole bunch first. NLS would be impossible. I believe this is my clutch causing this. 4. Whatever clutch they got in this holds extremely well. Zero slip at all in any gear. The problem is the engagement is RIGHT on the floor. I am seeing this is a common thing with aftermarket clutches in our cars. I have bled the crap outta it and am certain it's not the fluid. The fluid will be changed tomorrow. My local stealer didn't have any in stock. I ordered 2 quarts off amazon for 1/3 the price the dealer wanted. They wanted $37 PER QUART!!! Damn they're proud of that stuff. What are your guys thoughts on this? I am going to get under the dash soon and see if the push rod is bent. If it's not I will probably order the adjustable rod/master cylinder combo. I figure if I can get just a TAD bit more dis-engagement when shifting at high rpm's that it would probably shift like it should. This may even make me stop hating the shifter. I believe the transmission has been apart at one time or another. There's a clear line of aerobic sealant along the case halfs. Doesn't GM / Saab use silicone there? This car definitely has the LSD in it. It's got the right code in the trunk. It most definitely spins both tires when it should. No one legged burnouts *roads have been wet*. The tag on top of my transaxle does NOT have the LSD part printed on it. Didn't all the LSD transaxles have LSD as part of the code on that tag? Edit: On a positive note. This car is extremely clean. The engine runs great and pulls HARD!!!! I like it. I picked up a HPTuners cable tonight and am going to go out and try to read the ECU. I hope it's not Trifecta locked. Thanks people for any input on these matters. |
What shifter does it have?
your reverse should have a lock-out. You need to pull up on the shaft to get into reverse.
IF the aftermarket shifter was not installed correctly that is your reverse engagement problem. As for the clutch pedal, could be a shot clutch. The 3.82 Gear Trans. didnt have LSD printed on the trans tag. If the # on the tag ends in a 6 (i think, it could be 5) it has an LSD. 4.05 Trans had LSD printed on there. |
Post a pic of the shifter, it could be the issue with crappy reverse lockout placement which can be a pain in the d*ck.
Also get used to going first then to reverse, it's become a habit for me |
Time to flush the brakes/clutch. Hydraulic actuated systems are notorious for the issues, outside of the reverse problem, you listed. The reason I say brakes and clutch is because they share a common reservoir.
For the reverse issue, I've always found it best to shift into third and then into reverse. Good luck! |
Trouble shifting at high RPMs can point to shift cables. I have the same issue in mine and Powell recommended replacing the shift cables. Apparently they don't have sufficient shielding and get compromised by overheating. Powell says he sees it all the time in the LNF. I have the new ones but haven't replaced them yet so I can't tell you for sure that it solves the problem but if Powell says so that is good enough for me :)
Ur shifter cable probably needs adjusting. When I put in sts, my reverse started doing same
Its most likely your cables or shifter. My twm has issues going into reverse. No problems with my ottp one tho
You just do a write entire on HPT.
(Post 7573198)
Originally Posted by YelloEye
(Post 7573075)
(Post 7573097)
IF the aftermarket shifter was not installed correctly that is your reverse engagement problem. As for the clutch pedal, could be a shot clutch. The 3.82 Gear Trans. didnt have LSD printed on the trans tag. If the # on the tag ends in a 6 (i think, it could be 5) it has an LSD. 4.05 Trans had LSD printed on there. I will check out my tag again and try to get more info on specifics.
Originally Posted by ECaulk
(Post 7573099)
Originally Posted by T-Man
(Post 7573123)
(Post 7573131)
Please do let me know though if those cables solve your issue.
Originally Posted by tomj77
(Post 7573185)
Originally Posted by double clutch
(Post 7573190)
(Post 7573198)
(Post 7573204)
Um what?
Here's exactly what my shifter looks like. Alcantra shift boot and Round knob just like in their picture.
Chevrolet Cobalt SS/SC Short Throw Shifter |
By the way, I have to wonder. After inspecting the plastic shift tower and the bull$hit interlock system. Why not just cut that plastic blocker off. You know, the one that prevents reverse unless you lift the knob?
98% of all 5 speeds in the world do not have this blocker bull$hit setup anyhow. It's a saab thing....... |
You can cut it mine was broken/cut off when I installed my short trow shifter that's when I noticed lol but mine works great I have the ottp shifter tho
its there for a reason... obviously. If you want to get rid of it go for it.
You say its not the shifter but at the same time you want to remove the lock-out .... seems like a contradiction |
I think its that shitty twm. No amount of cable adjustments could get mine to go into reverse smoothly but my ottp one on the exact same car is completely fine.
Originally Posted by Snail_SS
(Post 7573263)
(Post 7573289)
(Post 7573295)
Does anyone know if these transmissions have an internal reverse/fifth gear interlock mechanism. It acts like it does and blocks reverse at times. Yesterday the whole day it worked just fine.......imagine that. |
Yup I have to mess a bit with mine but I'm used to it already so don't care lol but yes reverse is all the way to the right and down for 5th I have to go a bit to the right then up and that's what I want to fix but I'm already used to the shifter so it's no biggie
(Post 7573319)
Thanks! |
No problem man
TWM reverse lockout is aluminum, says so right on the page.
(Post 7573380)
That^
Ahhh. You can replace that. #19 in this diagram GMPN: 20763149
http://www.wholesalegmpartsonline.co...181A04-023.JPG |
hey, have you ever figured this out? my 08 (or 09.. not sure) is the exact same way. its not overly hard to shift at low rpm but while driving and doing WOT runs its impossible. i have a couple k20 buddies who get in it and go wot and try to quick change like a typical honda and they pop the cables out of the clamp.. the cables are brand new and i replaced the roll pin in the linkage. i lost the engine 2 months ago and am doing a full build including all front end parts. i have the entire front end ordered, the billet engine mounts, and transmission mounts. i also am doing a new clutch with oem flywheel, ottp shifter, and anything that could possibly be hindering my shifting. id like to know where you got with this because what you describe is identical to my issue.
