Side exit 3" exhaust + catless DP = YUCK at WOT
Old Jan 6, 2010 | 10:25 PM
09CobaltSS1's Avatar
Cool Side exit 3" exhaust + catless DP = YUCK at WOT
So I just installed a ZZP catless dp tonight, and holly ******* **** is the car loud! Granted I have a 3" side exit cat back as well, which is relatvely loud to begin with, but oh my god it is rediculous now. The turbo sound I get when I'm just cruising sounds freakin sweet, but when I go WOT... YUCK... I'm going to put the stock exhaust back on tomorrow (minus the stock dp that is, I'm lovin the ZZP dp) and hopefully it will sound a little less like a car with a broken exhaust. Any thoughts on how that will sound? Will the full stocker be too restrictive?
Old Jan 6, 2010 | 10:33 PM
PrincessTurbo's Avatar
I run Catless DP With factory exhaust and IMO I think it is a perfect balance of loudness when you want it and softness if you don't , It has not been too restrictive at all for me .. Sounds good
Old Jan 6, 2010 | 10:34 PM
jaygo7007's Avatar
any sound clips
Old Jan 6, 2010 | 10:35 PM
ls1fbody's Avatar
Haz l33t wheelz.
catless DP with muffler delete = sexxxxx
Old Jan 6, 2010 | 10:42 PM
yeah I have been debating this but I have a feeling with no baffle in it you will get that ricey raspy ricer sound then you gotta weld the damn muffler back on if you don't like it ..
Old Jan 6, 2010 | 10:45 PM
Originally Posted by jaygo7007
any sound clips
I'll try to make some sound clips tomorrow before I swap exhausts. If I hated my neightbors enough, I'd go ahead and make some clips for you tonight..
yeah I get that super raspy/broken exhaust sound with this setup so I be worried about the same thing with removing the muffler.. although maybe not seeing as how the stock piping is only 2.25" in stead of the 3" I have.. ehh I don't know
Last edited by 09CobaltSS1; Jan 6, 2010 at 10:47 PM. Reason: Automerged Doublepost
Old Jan 6, 2010 | 10:50 PM
its not really the 2 inch pipes you're running which are more then enough to flow for a 300HP turbo car , its the cats in the stock downpipe that are the restrictive part, I think the muffler and catless is a perfect happy medium .
Old Jan 6, 2010 | 10:57 PM
yeah I'll be trying that combo tomorrow either way, so I'm sure it will be leagues better than what it currently sounds like. Plus I won't have a stupid big gaping hole in my rear bumper where my exhaust tip once was..
Old Jan 6, 2010 | 10:58 PM
06_ion2's Avatar
yep it will be loud. lol what did you expect?
Old Jan 6, 2010 | 11:21 PM
Iam Broke's Avatar
I'm running the ZZP catless DP on the stock catback. It's just right...except at 4am in cat warmup mode.
Old Jan 6, 2010 | 11:56 PM
burnrubr88's Avatar
to all the people that think their car sounds good from inside the car....give your keys to a friend and let him pass you at WOT
Old Jan 7, 2010 | 12:04 AM
elecblue06's Avatar
damn man.. lol i coulda told you that .lol.. but ps the stock exhaust is 2.5 "
Old Jan 7, 2010 | 12:17 AM
06_ion2's Avatar
Trusting said friend with a car they cannot handle is a very good idea. expecialy a wot pull
Old Jan 7, 2010 | 12:20 AM
burnrubr88's Avatar
Just sayin. I thought my car sounded amazing from the inside, then i let a friend drive it and was like eww
Old Jan 7, 2010 | 12:23 AM
ryanstammler's Avatar
any pictures of the exhaust? or sound clips?
Old Jan 7, 2010 | 12:36 AM
06_ion2's Avatar
can only help catless 3in so much.
Old Jan 7, 2010 | 12:38 AM
BartSS's Avatar
I'm running a catless dp and a full 3" all the way through. I have a muffler but no designator or anything and I and everyone I know likes the sound. I had a buddy of mine record a WOT pull and I like it
Old Jan 7, 2010 | 01:00 AM
cmiller8006's Avatar
Catless with a muffler delete sound real close to this. So if you want quiter make sure you have a muffler.
Old Jan 7, 2010 | 01:01 AM
Alleynejl's Avatar
hey where did you order the side exhaust and was it easy to install??
Old Jan 7, 2010 | 05:31 AM
Sweetsandman's Avatar
If you're not running a larger turbo...then no...it won't be too restrictive at all...and it'll sound sweet as hell.
Old Jan 7, 2010 | 05:34 AM
mrsilent13's Avatar
i approve on the muffler delete and catless dp.....the ss/tc sounds sweet like that
Old Jan 7, 2010 | 10:05 AM
lol.. yeah I knew it would obviously be loud, but this just sounds like canned ****
nope.. the exhaust is 2.25 ID.. it's 2.5 OD but who cares about the OD measurement for exhaust piping
I'll work on getting a sound clip today.. it really sounds sweet when just cruising around and you listen to that turbo spool, but other than that... yikes
it's a Jennetty side exit, and yeah it's super easy to install.. the longest part is deciding where oh where to make the cut on your stock exhaust just in case you might need to reuse it at some point.. it sounded great with the stock DP just not catless
Old Jan 7, 2010 | 10:14 AM
BYT*SS*TURBO's Avatar
Reduce the Spark Advance in the ECT SA Table and that goes away
To the OP: I run the ZZP DP and stock exhaust and I like the sound a lot. As others have said, it's a good mix of quite and loud! You can make plenty of power using the stock exhaust also
Old Jan 7, 2010 | 10:17 AM
rico's Avatar
um i was thinking of doing 3 in side exhaust on my swapped turbo lsj. the dp has a cat. but dang idk if its going to be too loud now lol
Old Jan 7, 2010 | 10:22 AM
ok sweet.. I trust your oppinion, and I will know for sure later tonight when I do the swap. Can you still hear the turbo spooling through the exhaust at low rpm? That is by far the coolest part of this setup.. not cool enough to keep the side exit on though imo
